taking out rear brake pads???
Old 02-20-2009, 06:13 PM
eodjeep2000's Avatar
Ok...I'm feeling pretty stupid. What's the little trick to getting out the rear pads? I have the caliper pulled but I can't see how to pull out the pads without damaging the little clip...?
I swear...I usually have a brain....
Old 02-20-2009, 06:34 PM
Mickey1234's Avatar
The pads should pull out, once you have the old pads out use a C clap to push the cylinder back in and replace with the new pads bolt back up, pretty easy.
Old 02-20-2009, 07:40 PM
I figured out something better...at least far better than what I was doing...
I initially took out the caliper and carrier as a unit since my main issues (I thought) were with a wheel bearing. I didn't realize that those were meant to be separate.
I thought things out and did the other side by compressing the caliper still on the rotor and then removing the caliper itself....worked super easy.
Thanks,
D
93-12Smoke
08-28-2011 12:22 AM
Chip
06-21-2009 03:59 AM
GUMP
05-26-2008 08:26 PM
hink
15
02-10-2008 12:52 PM
Betsy II
05-12-2007 06:45 AM
Quick Reply: taking out rear brake pads???
