TailGate Will Not Close Properly
Old 03-12-2004, 09:45 AM
twhite's Avatar
My tailgate has developed a closing problem. When I close the tailgate, it bounces back at me. I immediately close it a second time and it closes properly. Yesterday I sprayed all connections with a lubricant. I just opened the tailgate for the first time today and I had to try to close it twice before it would latch.
Any suggestions?
Old 03-12-2004, 12:57 PM
Crimedog's Avatar
Mine does that, too. It helps to manually push the tabs on the side latches towards the front of the truck before you shut it. It has me
Old 03-12-2004, 04:40 PM
99 cummins's Avatar
Just in case any tailgate experts are out there I'l throw my problem in the loop here. My tailgate wont open wth the handle. The handle releases one side of it but the other side I have to reach to the inside of the gate latch and theres a littlte bitty latch there I have to pull up on. This may tie into the previous postings if the catches aren't letting go completely.
Old 03-12-2004, 04:50 PM
DPG
DPG's Avatar
twhite: My tailgate developed the same problem. I used WD-40 and squirted the inside of the tailgate where the handle is attached and that took care of the problem. Tailgate's worked perfectly for the last 5 months.
DeWain
Old 03-12-2004, 06:25 PM
twhite's Avatar
DeWain
I used a similiar product and sprayed the handle well (or at least I thought so). I will try again. Maybe it needs just a little more encouragement.
Old 03-13-2004, 01:37 AM
AlpineRAM's Avatar
I had the same problem. Popped he handle guard out of the tailgate and got acces to the scissor that pulls the rods to release the tailgate locks. All that stuff was really rusty and covered with salt, so I took tha garden hose to it and washed everything out. The door worked great again, so I added some oil for protection.
AlpineRAM
Old 03-13-2004, 07:22 AM
berner's Avatar
Mine was doing this too. I loosened the handle and twisted the tie-rods with pliers in effect shortening them. Works great ever since.
Old 03-13-2004, 07:37 AM
BIGBADBOB's Avatar
Mine did the same so I unbolted the two latches and pulled them out a little and lubed the pin in there that fixed it. The sticky latches cost me a storage door on the 5th wheel when the gate dropped down in an intersection. That sucked.
Old 03-13-2004, 11:01 AM
twhite's Avatar
AlpineRAM
How do you "pop" the handle guard out of the tailgate? Use a wide blade and work it out?
Old 03-13-2004, 03:29 PM
AlpineRAM's Avatar
I used a flat screwdriver with insulation tape wrapped around it. Just pulled out the lower side of it a bit until it came loose, pulled the handle and caught the guard bit (almost- well actually with my foot )
AlpineRAM
Old 03-13-2004, 07:32 PM
Crimedog's Avatar
Mine popped off because I have to slam it so hard to close it! Maybe it is trying to tell me something... I'll give it a big shot of lube tomarrow.
Old 03-13-2004, 11:00 PM
kingofdodge7131's Avatar
my 99 started having the problem latly that it wont stay shut! sometimes it falls open drivin down the road
Old 03-14-2004, 09:42 PM
DTR's Cow Boss
DodgeCowboy's Avatar
mine rattles and i live on a 5 mile dirt road and iam about ready to throw it off the intersate bridge or strap a come along on the opsoing stake pockets and ratchet the you know what out of it. its really annoying
Old 03-17-2004, 03:42 AM
pcabe5's Avatar
It might be adjusted to tight. Try adjusting the two pins on the bed out about an eighth of an inch and see if that helps. Mine only does it when its 20 below or colder. If the pins are to far forward the gate cannot go far enough forward to make the latches grab. I've seen this on a few trucks not just the Dodges.
Old 03-17-2004, 09:47 AM
Cowhand's Avatar
Is there supposed to be some kind of bushing in the lower hinge pin? Mine rattles like heck, and it moves back and forth on them hinges enough that it chips my new paint when the tailgate is down.
Quick Reply: TailGate Will Not Close Properly
