Tailgate L.E.D Firing Strip
Old 04-04-2007, 05:56 PM
chuck gibson's Avatar
Smile Tailgate L.E.D Firing Strip
Just installed works great bought from hubcapsplus.com great price. works with blinkers , brake and back up lights plugs in to the 4 pin trailer plug.
Old 04-04-2007, 06:17 PM
rjm022's Avatar
i bought the line of fire last year. no problems with mine so far!
Old 04-04-2007, 06:44 PM
morkable's Avatar
I have the fire and ice one,,I like it, going to add one to my new truck too
Kevin
Old 04-04-2007, 08:35 PM
butchb's Avatar
How did you get backup lights with a 4 pin connector, I had to tap my reverse wire?
Old 04-04-2007, 08:39 PM
rjm022's Avatar
my line of fire plugged right into the factory 4 pin connector
Old 04-04-2007, 08:46 PM
butchb's Avatar
Yes, but I didn't think 4 pin connectors have a reverse wire? Chuck said "works with blinkers , brake and back up lights plugs in to the 4 pin trailer plug", so I am cornfused.
Old 04-04-2007, 09:26 PM
rjm022's Avatar
the regular line of fire, which is the blinkers, running light and the brake light- plug right into the 4 pin connector-maybe the new ones that also have the reverse lights, require plicing the into the reverse lights??
Old 04-04-2007, 09:28 PM
35" 05''s Avatar
keep an eye on it. Mine and my buddies popped off. I think its the humidity here.....and yeah we did clean with water.
Old 04-04-2007, 11:28 PM
morkable's Avatar
Yeah if you have the fire and ice, you will have to tap into the reverse light wire. So far mine has stuck on without a hitch, which is quite amazing here. We have an amazing changes in temps. From 100 above, to -40. No problems so far, but I did take extra care when installing it.
Kevin
Old 04-05-2007, 05:08 AM
rjm022's Avatar
popped off?? mine is held on by 3 or 4 stainless steel bolts/nuts.
Old 04-05-2007, 05:27 AM
P.J
P.J's Avatar
Mine (60" Recon Fire and Ice) is held on my 3M adhesive tape, it is then bolted to those (taped) tabs.
Reverse wire was a white one on mine, pop out the drivers side signal, tap the wire, done.
Old 04-05-2007, 06:26 AM
Totallyrad's Avatar
I like the fire and ice idea but I have not seen where the function of the back up lights are worth the money. The LED's are so small that their light output is minimal. I did see something that I liked on Recon's site and that was the white LED's for under the bed rails. I have to hook and unhook a GN after dark on a pretty regular basis and those would be nice. So I wonder, and because I do like lights, what if................you put a fire and ice strip across the top of the cross over box and put the "ice" on a toggle switch? Probably a little too "red" huh?
Hercules
12-31-2009 12:49 AM
sammy340
03-11-2006 09:43 PM
Timmay2
02-13-2006 08:51 PM
StrokeThis2500
11-17-2005 08:47 AM
DeaconWayne
03-26-2003 05:20 PM
Quick Reply: Tailgate L.E.D Firing Strip
