Tail Light Problem
Old 04-17-2006, 06:09 PM
Msiemens's Avatar
Tail Light Problem
I have ecountered a problem with my truck, no left side tail light, but the signals and brake light still work. It operates off of the same bulb but I can't find the culprit. It is probably staring me right in the face and just can't see if.
Just hoping that someone else knows what the quick fix
Old 04-17-2006, 06:45 PM
John Faughn's Avatar
Its the same bulb but that bulb has 2 differant filiments in it , 1 brighter for brake & turn , the other dimmer for tail lt.
sometimes looking at the bulb you can not see a burnt filiment , while holding bace with one hand , tap the bulb with finger nail , and you should see the filiment wiggle .
When you pull the bulb , look into the bace [ truck end ] you'll see 2 metal nubs off to either side , those are the positives for either curcit , the outside metal coller is the negitive for both , carefully put a test lite on both of the center contacts to look for power with either light on , put a pice of tape around the shaft of the test lite as to not contacted the ground .
This should get you in the right direction , bulb/ truck.
Old 04-17-2006, 06:50 PM
Msiemens's Avatar
Thanks.... I have tried different bulbs, I am sure that it is the truck...just don't know what/where.
Thanks.
Old 04-17-2006, 07:05 PM
Its comin to lose it at the splice for the trailer , especaly if its been done after market.
Other wize a lest lite again and follow the harness to the front , find a wiring diagram , with those 2 you'll be in the ame boat as the experts , finding and open curcit can be just a hunt & peck till you find it .
DIESELWRKS
08-09-2011 01:36 AM
Viperdew
01-02-2009 12:13 AM
GoinAndABlowin
02-11-2008 11:40 AM
phantom_ram
05-08-2007 12:30 PM
TGriffith
12-08-2006 10:34 AM
Quick Reply: Tail Light Problem
