tachometer
tachometer
i may have the opportunity to buy a tach out of a 92 being parted out.
A how much should i give for it granted it works? pictures show that it looks good, but pictures can only do so much lol
B what all would i need with it? do i need to get the wiring harness pulled too? or is there a plug n play in my 93 straight from the factory?
thanks ya'll
thanks ya'll
You have the plug and play. The empty plug is taped up under the dash to the left of the steering column. You should only need the wire coming out of the tach that passes through the dash and plugs into this plug. In all about 18".
