Tach Woes
Old 07-04-2007, 04:39 PM
Loosewire's Avatar
Tach Woes
I Purchased A Autometer 2888 Alternator Accuated Tachometer. The Instuctions Say To Put The Induction Pick Up Over The Laminated Portion Of The Alternator Housing. My Alt. Doesn't Have These. Can Anyone Help Me Out Here? Will This Tach Work On My Truck? Thanx.
Old 07-04-2007, 07:19 PM
91.5CTDBanks's Avatar
The laminated part should be the center of the alt. where it looks like layers sandwiched together. If it does not have this design you can just strap the sender in the center of the alt. with the clamp. It should still work.
Old 07-04-2007, 08:00 PM
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
Mine doesn't have laminations showing either. I just temporarily hooked it up so I could see it while under the hood. Then I moved the pickup around until I got a good solid reading. Then I clamped it there. The signal will go through the aluminum case just fine.
If you have access to a diesel shop tach you can set it OK but rev the engine up to get a more accurate reading. I borrowed an optical tach and put reflective strips on the HB to get a reference value.
Edwin
Old 07-05-2007, 05:01 PM
You may have to tweak the positioning to get a good reading at high RPM. When I first installed mine, it would flatline at 2k. A little adjustment of the sensor and it read as high as I was willing to spin it.
CumminFast
17
12-10-2004 09:57 PM
Cummnzpowr
07-14-2003 08:43 PM
Dieseldude4x4
13
06-13-2003 07:17 AM
Bluedresser
04-16-2003 05:45 PM
Lary Ellis (Top)
16
11-16-2002 03:07 PM
Quick Reply: Tach Woes
