tach wiring in my 92 w/a isspro r8503
Old 11-06-2010, 11:18 AM
ratherberacin's Avatar
hey guys couple questions. just going to put my new isspro tach i got from DNR
from previous posts here i know i have a tach plug in under the dash and the wires are as follows.
black -12v gauge lights
orange 12v common
red-switched 12v
grey w/blue tracer- tach signal
on my isspro r8503 there are three wires are coming out (other than the light harness)
white
red
black
they say on their universal crappy instructions.
white to one of the sensor wires
black wire to the other sensor wire (ground as close as possible to the tachometer head( not sure what the "other sensor" wire means
red wire to 12 keyed power.
so before i melt anything let me see if i have it figured out.
white tach wire to grey/blue tracer tach signal wire
black tach wire to ground
red tach wire to red 12v wire.
sound correct?
Old 11-06-2010, 01:54 PM
deanhinsley1963's Avatar
sounds right to me.
Old 11-08-2010, 07:29 PM
Received 1,332 Likes on 862 Posts
Is this the Isspro set-up with the magnets on the balancer? If so I did mine not long ago. The magnetic pick-up had 2 wires, one wire went to common ground, gauge and the sensor, and the other went to the white off the gauge. The rest was as you stated.
Old 11-09-2010, 07:34 PM
ClassA4x4's Avatar
You're connections is right, BUT if you're not using the ISSPRO harness that they sell your setup won't work. Go to your nearest Radio Shack and buy a $1.79 0.0047 microfarad capacitor and insert it between the sensor wires. You'll be amazed how magically it works.
Old 11-09-2010, 08:08 PM
Billut's Avatar
So, you'd put the capacitor between white tach wire and grey/blue tracer tach signal wire, that's it ?
Old 11-09-2010, 08:43 PM
DNRCustoms's Avatar
Well, I will try this. Beacause on a few trucks even with the Isspro harness the tachs have been giving headaches. Called isspro several times and they were little help.
Old 11-09-2010, 10:43 PM
366 Spring Chicken
Richie O's Avatar
Have you talked to Don Wendlick at Isspro? He has helped me before and actually called me to check up on it. Some styles need the capacitor and others do not.
Old 12-01-2010, 12:28 PM
ClassA4x4's Avatar
Yes. I hope you got it working already.
Old 12-01-2010, 12:29 PM
ClassA4x4's Avatar
Yes, i've talked with Don but from him what you have to do is their "trade secret"; they sell the harness. so I took it upon myself to research tach circuits that led me to the capacitor solution.
Old 02-13-2014, 10:32 PM
1992gen1_fan's Avatar
Dug up an oldie, needing to make a harness for a r8503 tach.
Would prety much any 0.0047 capacitor work? or does it need to be uf or pf ect..? I looked on radio shacks website and could only find the little disk type capacitors. I don't know electronic stuff
Old 02-14-2014, 06:45 AM
ClassA4x4's Avatar
Yes, I'm using the Radio Shack .0047 microfarad disc capacitor, but any .0047 uF (not pF) would work.
Old 02-15-2014, 01:06 PM
Ok thanks for the info. I stopped at a local electronic repair business and closest thing he had was a .005M 1KV capacitor. Was only 50 cents so I bought one just in case. Would that be close enough?
Old 02-15-2014, 01:46 PM
ClassA4x4's Avatar
Close enough
Old 02-15-2014, 03:05 PM
Cool, thanks
Old 02-28-2014, 11:53 AM
56speedy's Avatar
1992gen,
Did that work for you and does your tach work now.
Power Ram 250 C
06-11-2007 09:54 PM
csramsey640
09-13-2005 01:00 PM
mainer
06-20-2005 05:57 PM
'80Toad
04-10-2005 03:47 PM
Quick Reply: tach wiring in my 92 w/a isspro r8503
