T Case swap questions
Old 11-01-2011, 10:06 PM
Buzz'nhalfdozen's Avatar
hello all
I have a 97 club cab CTD 5sp dana 80 with a 241 LDL T case. i just got a 96 club cab a v10 auto dana 70 with a 241 HDH. the 96 has no title and i am robbing parts off it. it is a complete truck. i want to put the 241HDH in to my 97 but am not sure on weather it will bolt up or if its the same length or if the input splines are the same and if the out put shaft u joint will work on my 97 drive shaft? any help would be much appreciated
Old 11-02-2011, 07:49 AM
patdaly's Avatar
Input shaft on the TC will have to be swapped, manual is 29 spline, auto is 23. Parts book shows same input between HD and LD units, so you should be able to simply swap them.
Old 11-04-2011, 09:43 PM
thanks so much for the info. gonna get it out this weekend and try and get the new one in.
wyododge
08-18-2011 07:48 AM
rhino 660
04-22-2007 10:26 PM
getblown5.9
01-27-2007 01:36 AM
4RnrRick
01-10-2007 11:31 AM
Quick Reply: T Case swap questions
