t.case rear output shaft yoke nut
Old 01-18-2010, 08:46 PM
Rick 12v CTD's Avatar
What size is that sucker? I don't have a socket big enough and so I have to go buy the right one tomorrow. All I know is that it is bigger than 1 1/4"
Almost seems like it would be a metric size. It's not much bigger than 1 1/4" though.
Anyone know? I'd rather not buy the wrong one and have to make 2 trips to town, if you know what I mean.
I deperately have to change out my rear output shaft seal on the case. It's leaking REAL bad. like a quart and a half (or more) in 1200 miles.
It's times like that that I wish I owned caliper. Maybe I should go buy one of them little doohinkies tomorrow too if it's not too much money
Thanks in advance,
Rick
Old 01-18-2010, 08:48 PM
hmknight's Avatar
I believe it's 1 5/16", went through the same thing when I went to change my rear seal.
Old 01-18-2010, 08:52 PM
well thanks. If a 1 5/16 fits over the nut it will get the job done!
Old 01-19-2010, 06:26 AM
Bob Beauchaine's Avatar
When you put the nut back on it needs to be tight - over 200 ft/lbs. It is what keeps the speedo drive gear tight. Otherwise you might find you have either a non functing speedo or one that bounces. If you need the exact spec. post and I will get it for you.
Bob
Old 01-19-2010, 05:07 PM
boooo.... at least I have a good torque wrench...
I think it goes to 240 ft lbs or something.
Old 01-19-2010, 06:09 PM
Twisted Inc.'s Avatar
id like to know what the specs are on both the rear input and front input nuts.....i just changed both my seals....there definitly tight but i dont know if there that tight....thanks!
Old 01-19-2010, 08:10 PM
sdseva's Avatar
Ditto on the torque specs I just did front and rear on mine and I know they arnt that tight.
Old 01-19-2010, 08:38 PM
The torque spec on the rear yoke nut is 280 ftlbs. I will have to dig out the other specs.
Bob
Old 01-19-2010, 09:37 PM
Bob
holy smokes. that's higher than I was expecting.
Old 01-20-2010, 02:34 PM
I hope this is what you were looking for:
Front/Rear Bearing retainer bolts : 22-30 N-m (16-22 ft lbs)
This is right out of the '93 Service Manual.
Bob
Diesel Head
03-17-2012 08:21 PM
sdseva
10-17-2010 06:16 PM
D1EZEL
11-22-2007 02:55 PM
SOOT4BRAINS
11-08-2007 04:52 PM
1stGenBikeHauler
01-25-2003 12:31 PM
Quick Reply: t.case rear output shaft yoke nut
