Synthetic weights and amounts
Old 05-04-2004, 12:04 AM
99 cummins's Avatar
Now that I'v decided to change over to synthetic fluids can anybody tell me a good weight of lube and the amounts it takes for the following parts
front diff
rear diff
transfer case
5 speed naual tranny
power steering pump
i think thats all of em, but if I'm missin one jump in and let me know.
Old 05-04-2004, 02:10 AM
BigBlue's Avatar
Don't forget motor oil.
Old 05-04-2004, 02:55 AM
99purplecummins's Avatar
to expensive for as often as it gets changed Tyler
Old 05-04-2004, 07:30 AM
Ruralmedic's Avatar
If your front axle is the Dana 60, it's listed fluid capacity is 6.3 - 7.3 pts. A 75W-90 should work well here.
I assume you have a Dana 80 rear axle, it's capacity is anywhere from 6.8 to 10.1 pts.
A 75W-90, or XXW-140 if towing alot would work here. If it's limited slip, you may need additional friction modifier if the clutch packs chatter. I wouldn't get it right away, unless the clutch packs chatter after you change the fluid out. I've got Royal Purple 85W-140 synthetic in mine, and it didn't require the FM.
The OEM fluid in the NVG4500 is Castrol Syntorq LT, which is a 75W-85 GL-4 synthetic fluid. Stock capacity is 4 quarts. Other than the OEM, I've found a 50/50 mix of Redline's MTL/MT-90 GL-4 synthetic manual transmission fluid works well at a fraction of the cost.
The NV241 standard transfer case takes 5 pts. If you have the HD version, it takes 6.5 pts. ATF is the fluid in here. Although Redline's MTL would work as well.
I don't know the capacity of the PS system. I used 1 quart of Valvoline Synpower in mine, by suctioning a little a time out of the pump until I had the entire quart in the system.
Good Luck!
coldtaco
04-28-2011 10:04 PM
Foxborough
09-13-2007 10:09 PM
avdunn
02-07-2007 04:07 PM
swank
03-11-2006 06:15 PM
B.Law
02-06-2005 12:48 AM
Quick Reply: Synthetic weights and amounts
