what synthetic
Old 11-23-2003, 12:30 PM
More Power's Avatar
what synthetic
Going to change my 2001 6speed fluid how much does it take and what do you recommend
Old 11-23-2003, 12:51 PM
Dr. Evil's Avatar
Re:what synthetic
The factory fluid is supposed to be good for a lot of miles......
A lot of guys are using the Red-Line MTL with great results. Another option is AMSOIL.....9.5 pints. I believe the drain is at the PTO cover....
http://www.dodgeram.org/tech/transmi...5600_spec.html
Old 11-23-2003, 01:03 PM
More Power's Avatar
Re:what synthetic
Everthing i needed thanks
Old 11-23-2003, 02:42 PM
Ramflasher's Avatar
Re:what synthetic
I use Redline MTL in my 6spd. It seems to work well, and a bit better than the amsoil I had in it prior to that. Not trying to start a brand war, only my opinion.
If you remove the entire PTO cover from the driver's side, you can wipe the magnet clean the is placed on the bottom of your tranny...use a lint-free cloth.
I replaced it with a gasket under the PTO cover, too. I like gaskets better than just using some type of RTV or whatever...
Old 11-23-2003, 05:01 PM
More Power's Avatar
Re:what synthetic
I looked on summits website and i cant find anything called MTL
Old 11-23-2003, 08:23 PM
Ruralmedic's Avatar
Re:what synthetic
I'd recommend Red Line MTL(manual transmission lubricant)also.
I have MT90, thicker version of MTL, in my NV4500 5 speed, and it shifts much better now. A lot better than the Amsoil stuff I was led to believe would work.
Old 11-23-2003, 10:24 PM
Dr. Evil's Avatar
Re:what synthetic
Wasnt too hard for me to find it:
http://www.redlineoil.com/dealers.htm
Give them a call @ 800-624-7958 OR 707-745-6100
Pa outlaw
17
01-19-2003 07:40 AM
ramman21921
01-17-2003 08:58 AM
perk
01-16-2003 09:51 AM
rshelton88
19
01-12-2003 10:26 AM
ronster
11-01-2002 04:14 AM
Quick Reply: what synthetic
