synthetic engine oil
Old 01-04-2010, 06:02 PM
93John's Avatar
Anyone running synthetic engine oil in this cold weather.. its been about 0 degrees with a wind chill of -10F. 15w40 has been taking a little time to build pressure. I didn't know about maybe a 5w40 synthetic would be better.
Old 01-04-2010, 06:13 PM
nelrod's Avatar
I am not an oil Guru, but I would definitely run the very oil you mentioned if I lived where it was those temps. I think you are right, 5-40 would be an excellent choice. Maybe those DTR Dudes in Alaska will chime in, they ought to know all about what is best for those temps and far below. Probably could just run it year round without problems. A couple worth mention that won't break the bank are Schaeffers or Rotella in 5-40.
Old 01-04-2010, 06:17 PM
14racing's Avatar
I'm runnin 5w-30 amsoil and the oil pressure gauge doesn't seem to really come up much faster than my dads runnin 15w-40. It does crank over much better with the sythetic. Have you ever tried to pour regular 15w-40 when its zero out? It ain't pretty. The synthetic pours much better. I bet you would be happier with running a lighter weight synthetic.
Old 01-04-2010, 06:26 PM
olddodgetrucks's Avatar
take a qrt. of dino oil and qrt. of sytn. in your fezzer overnight to convince yourself
Old 01-04-2010, 06:32 PM
maybe368's Avatar
Ditto for hot weather also....As said from Phoenix where 70 degrees is a cold spell
Old 01-04-2010, 06:40 PM
SSchofield's Avatar
I use Mobil Turbo Diesel Truck 5W-40. I have very little crankcase bottle vapors due to my switch. I am very happy with this oil too because consumption is zilch.
Old 01-04-2010, 06:56 PM
1ST General's Avatar
ROTELLA T 5W-40 SYNTHETIC MOTOR OIL + 1 LUCAS SYNTHETIC . The truck sat for three weeks fired up fine.Well worth the extra money.I've used it for three winters.
Old 01-04-2010, 09:34 PM
93 12v's Avatar
Does 15-40 make anyone elses truck idle slow when cold and rise as engine warms up? I had synthetic delvac until 2 mos ago, and it was as smooth as butter at cold start-up.
Old 01-04-2010, 11:15 PM
cell's Avatar
5w40 Citgo SynDurance for the last 10,000 miles starts great.
Old 01-04-2010, 11:22 PM
u.s mma's Avatar
5-40 rotella. 19 bucks a gallon at wally world. topped off the p.o.s the other day at 15 below, flows pretty decent. stinks something wierd though.
Old 01-05-2010, 12:21 AM
ppiggppenn's Avatar
I've used Castrol Syntec 5W50 year round for several years now, ... consumption negligible as mentioned above, and cold starts not a problem. It's about $100 with the filter per change, but nothing's too good for my old reliable work-horse
Old 01-05-2010, 05:43 AM
dzl_damon's Avatar
I had trouble starting my old mercedes diesel in -10 and lower weather. Would NOT crank over fast enough for me. Put in a new battery and nothing better. Changed the oil from 15W40 - 5W40 and it turned MUCH faster and started in the same weather without being plugged in.
That was the most convincing side by side evidence I've seen. I was very suprised at how much it helped.
Old 01-05-2010, 08:31 AM
raggmann's Avatar
I'm with ppiggppenn,it cost $100-110 here for the filter and oil but I won't run regular oil any more. I personally run either Shell Rotalla T or Chevron Delo400 in 5W40 synthetic.
I've swapped the oil in the transmission to synthetic as well.It seems to shift a LOT better when it's -43c.
Old 01-05-2010, 08:43 AM
maybe368's Avatar
I bet this makes Hugo Chavez happy
Old 01-05-2010, 01:24 PM
jesussaves's Avatar
X2
Do you guys switch back to regular oil in the summer or just run synthetice yr round??
Quick Reply: synthetic engine oil
