PDA
View Full Version : SYMPTOMS OF EGTS
1ST GEN.
10-19-2002, 12:34 AM
WHAT ARE SOME SYMPTOMS OF TO HIGH EGTS SUCH AS NOISE ROUGH RUNNING OR ANY THING ELSE
John_P
10-19-2002, 08:45 AM
1ST GEN:<br><br>I am not sure I real clear on what you are asking, but<br>I will try to answer your question. ;)<br><br>The &quot;general rule&quot; on EGT's is that you should not<br>exceed 1300 degrees if you pyrometer probe is<br>BEFORE the turbo (in your manifold) and it should <br>not go over 1000 degrees if the probe is after the<br>turbo (generally in the exhaust downpipe). Cummins<br>ran extensive &quot;high temperature testing&quot; on this<br>engine shortly after it was put into the Dodge <br>CTD trucks and one engineer told me that the<br>engine could take 1300 degrees &quot;steady&quot; with<br>no damage to the engine. &quot;Steady&quot; temperatures<br>above that resulted in stuck pistons, scarred<br>cylinders, etc. You can &quot;spike&quot; the temperatures<br>to as high as 1800 degrees, as I have done it<br>and so have many of the other members here.<br>But,.....you don't want to leave it there for<br>very long!!! :o <br><br>I have never experienced any noticeable <br>differences in the way my engine runs when<br>I have hit higher EGT's (1400-1800 degrees).<br>I am sure some of the other members can<br>add to this. <br><br>Hope this has helped you some. These<br>engines are TOUGH and can take an awful<br>lot, but they can be damaged too! Just<br>watch your pyrometer and if you don't have<br>one I would highly recommend getting one!<br><br>--------<br>John_P
