Switching mirrors
Old 06-27-2005, 03:12 PM
out4elk's Avatar
Question Switching mirrors
How hard is it to swap out my chrome (97) mirrors for the 98-02 outside mirrors? I have the power mirrors. Will the wiring match up? Mine are starting to get really loose and I like the look of the black ones better anyway.
Thanks in advance.
Old 06-27-2005, 04:43 PM
Rattlerattle's Avatar
They bolt right up but the wiring is different.
I put in the newer heated mirrors. The two black wires from the mirror was the heat.
yellow to red
light blue to green
white to blue
mirror to truck
Hope that helps.
Old 06-27-2005, 09:34 PM
12vordie's Avatar
Are you talking about the small mirrors or the big black towing mirrors? The big tow mirrors are not offered with power for the 2nd gen trucks, atleast none that I have found.
Old 06-27-2005, 09:37 PM
I switched from the power / unheated 95 stock crome mirrors to the similiar sized 98-02 power / heated ones.
Old 06-27-2005, 10:59 PM
mkubacak's Avatar
You can do a 3rd gen head to 2nd gen base conversion, or get some ****'s.
Old 06-28-2005, 09:38 AM
out4elk's Avatar
I'm talking about the smaller ones. I see them on ebay and they are reasonably priced. I assume that in order to get the heat option to work I would need to hook up some kind of secondary switch?
Thanks for all your help so far.
Old 06-28-2005, 10:44 AM
JKM
JKM's Avatar
What kind of cost is involved in switching from the chrome mirrors, or the black 98-02 mirriors , up to the big black tow mirrors?
Old 06-28-2005, 03:59 PM
I found a set of the small ones for $80 CAD. Hooked the heater up to a lit toggle switch. I guess you could forget to turn them off and probably break the mirror, but I don't use the heated feature for more than a couple of minutes in the morning.
When I looked into the larger tow mirrors they were at least 3 times as much as what I paid for the small ones. Supply and demand, eh?
ChicagoSnow
56
01-26-2008 12:09 AM
A_Manke
09-05-2007 01:25 PM
B.A.Ram
01-12-2006 07:29 PM
gwhammy
12-14-2004 09:41 PM
1320
04-30-2004 09:13 AM
Quick Reply: Switching mirrors
