switch from auto to manual
Old 06-24-2007, 02:48 AM
mullishacrew's Avatar
alright well heres the story, a guy at my local auto parts shop told me hes got a standard tranny with new clutch and linkages and the full set up for my truck all i need to get is the pedal and those parts, but i want to know if the swap is worth it? since i have an auto right now, i would like the standard. oh and it has a new clutch and is very good condition, but how much work am i looking into to do this? and my old man said no but to bad it's my truck i can do what id like to do haha, anyway any advice would be great
Gregg
Old 06-24-2007, 07:03 AM
Ace
Ace's Avatar
Well, it is alot of heavy work. Are you doing it yourself?
Old 06-24-2007, 08:28 AM
BHD
BHD's Avatar
Do you have a 2 or 4wd? If its 4wd you'll need to get the coupler between the tranny and t-case as well as a new input shaft for the t-case or the right t-case. The clutch works via hydraulics so there is no real linkage to mess with. It's really not a bad job if you have done transmission work before. Just take your time and find a good tranmission jack.
Old 06-24-2007, 10:06 AM
rbrettctd's Avatar
Im bout to do it. I just found out I may need a diff. tunnel. Anyone know if this is true?
Old 06-24-2007, 12:30 PM
Short Box's Avatar
Gregg[/QUOTE]
Listen to your Dad, someday you will realize how smart he really is.
Old 06-24-2007, 01:46 PM
RumbleFish's Avatar
^^^agreed, but i prefer a manual in whatever i drive. then when my dad wanted a ctd, he wouldn't even look at an auto.
Old 06-24-2007, 02:19 PM
it's a 4wd and he did say it comes with the bellhousing and all but now i have to check up on the transfercase stuff, it's a np205, and the kit that this tranny is comming from is the same set up he trying to sell from rad to transfercase whitch includes everything for $6000 but he said he would sell the tranny seperate along with everything it needs.
Old 06-24-2007, 02:23 PM
and i will be doing ity self, as iv done this kind of job on a old 64 ford 4x4 logging crew pick up truck and i did the job using a regular jack but i dont think it will reach up to my transmission, but my uncle do this kinda of stuff so they can help
Old 06-24-2007, 02:50 PM
PapeCAT's Avatar
well it'll be something where you'll need the manual xfercase as well, the auto one won't work! Easier to do on a 2x4 and I don't know all the snags on a 4x4 swap sorry guys!1 I've done the swap on my '89 2x4 and YES the tunnel is too small, you need the larger bolt in hump from a 72' - '89 4x4 auto/4sp or 2x4 4sp truck!! auto 2x4's have small humps!
fpr01
13
09-21-2008 11:31 AM
ezdemon72
07-29-2005 10:05 AM
antknee
06-19-2003 07:33 AM
Quick Reply: switch from auto to manual
