Sweet/musty smell coming from vents... bad heater core?
Old 02-11-2010, 11:50 AM
DTR question asker
dieselfuelonly's Avatar
I've started noticing a sweet/musty smell coming from my defroster vents... I have a vacuum leak and my vents are stuck on the defroster position anyway. It seems to show up periodically, sometimes I'll smell it and other times I won't.
I can smell it no matter if the fan position is on A/C or normal blower mode, as well as if the heat/cool selector is in either position. The smell is stronger if I have the fan at a higher speed.
Can't smell any coolant in the engine compartment or outside the truck, haven't spotted any coolant leaks, and no white smoke from the exhaust that would suggest a bad head gasket.
However, I haven't seen the condensation building up on the window like some have... but the temperatures have been around the 30s here for a while now, so would that only show up if it was warm outside?
Sound like a bad heater core to yall? I don't look forward to this job
Old 02-11-2010, 11:56 AM
hamilton71801's Avatar
Sounds like the a/c drain is stopped up and mildewing. Look on the outside firewall towards the bottom and see if thats it.
Old 02-11-2010, 12:02 PM
DTR question asker
Ok, I'll check on that. It definitely has a sweet smell as well to it, kind of like coolant, like taking a real deep breath of cold air through your nose... if that makes sense
Old 02-11-2010, 12:39 PM
heavyboostin's Avatar
def your heater core, i had that happen to me, took a while to replace because you basically have to rip the dash out but its easy work. the condensation will start before to long, let me know if you have any questions although its been several years since i replaces the core so i dont remember much
Old 02-11-2010, 02:24 PM
Just a plain ole guy
1-2-3's Avatar
If you have to replace the heater core, go ahead and do the evap core. it'll cost a little more but will save you in the long run.
Old 02-11-2010, 07:41 PM
and if your dash is cracked you might as well do it, i will be doing the dash here soon in my 97 which i did the heater core in.
Old 02-12-2010, 06:42 PM
WestTN's Avatar
That sweet smell is probably antifreeze.
Old 02-12-2010, 07:02 PM
Big Deezul's Avatar
pair of ladies underwear under the seat?
bcool
02-04-2008 10:50 AM
azmusclecar
09-30-2007 09:49 AM
plow
07-15-2005 01:53 PM
waam
06-02-2005 03:50 PM
hellotbone
06-30-2004 02:24 PM
Quick Reply: Sweet/musty smell coming from vents... bad heater core?
