Swapping rear end questions
Old 02-24-2010, 04:45 PM
whttacoma's Avatar
I have an 05 2500 4X4 auto with CTD and my buddy is going to trade in his 08 2500 2X4 Hemi that he said I can swap rear ends before he does. My diff is open 3.73 that has a lot of slop (backlash) with leaking pinion seal in it and his is Tru trak (posi) 3.73 that is tight with no leak. Is this going to be a simple swap or would there be more involved than I am thinking? They look pretty much the same to me.
Old 02-24-2010, 05:45 PM
NickBeek's Avatar
Did they use the 11.5 axle on the Hemi? If so, it could be done.
Old 02-24-2010, 08:18 PM
Administrator/Jarhead
madhat's Avatar
I am not sure, however, have him look in his glove box for an information sticker, it will tell you which rear end he has.
Old 02-24-2010, 10:00 PM
whttacoma's Avatar
I looked at the window sticker and it had 3.73 and Sure Grip or Tru Trak but nothing about it being 10.5 or 11.5. I went to mag-hytech and they had a note saying
AA 14-10.5 Bolt Pattern has two top and bottom bolts @ 11:00 & 1:00 O'clock & 7:00 & 5:00 O'clock for quick identification.
OR #AA 14-11.5 Bolt Pattern has one top and one bottom bolt @ 12:00 O'clock & 6:00 O'clock for quick identification.
I will have to look at the cover and see where the bolts are located.
Old 02-24-2010, 11:52 PM
nwflyoda's Avatar
i'm pretty sure he has the 10.5. that and i don't know how well those posi's will hold up to the torque form our motors. they are clutch style and the ones in the 11.5 are worm gear style.
GR40RCapri
10-30-2007 09:37 AM
doorguy
06-08-2007 06:19 AM
JKM
01-24-2006 08:24 PM
Flatty
01-17-2006 01:59 PM
Commatoze
11-22-2002 07:39 PM
Quick Reply: Swapping rear end questions
