Suspension lift with leveling kit
Old 09-07-2007, 06:44 PM
whitetrash66's Avatar
who here has done (or seen anyone do) this? The reason i'm asking is because i'm currently running a 6" BDS short arm kit, 20x10 wheels and 36x15.5R20 MTZs. I trimmed fender (some plastic and a little metal) and have no rubbing now.
I just ordered some new 20x12 rockstars with a 4.5" backspace. I'm worried about rubbing, so i'm going to put my old 2" leveling kit on to my BDS kit. Anyone do this and have any problems? i'm planning to upgrade to long arms in a couple of months, and i also am going to get BDS's transmission drop.
Old 09-07-2007, 06:58 PM
UNOUNVIT's Avatar
whitetrash66,
I have a 07 Mega Cab 6.7L with a 6" BDS Long Arm and 2" spacer up front, 5" Springs in the rear and 2" block, 37x13.50 Nitto Mud Grapplers mounted on 20" KMC Rockstars with 4.5" backspacing and bushwacker pocket flares.. All i had to trim was the plastic inner fender, i have no promblems with stacking the spacer, just make sure you play with the cam bolts on your arms figuring out what is putting your diff forward the most of course. Other then that i would recommend stainless breaklines!! Good luck with the add on let us know how it turns out.. I will try to get some pics of my truck up soon so you can see...
Old 09-07-2007, 07:07 PM
solostyle1's Avatar
I just did a 6" superlift with a 2" leveling kit. Im running 37/13.50/22 Rockstars. What I did was eliminated the shock "tri-pod" bracket. I have the bilstien shocks and with the leveling kit it made the shock basically fully extended. I cut a round piece of steel and drilled the 3 holes plus the 1 hole for the shock itself, and threw away the shock mounting bracket. It gave me about 3" extra for the shock to travel. I can turn the steering wheel both directions and i dont rub. If i hit a bump with the wheel turned ALL THE WAY then it rubs just a little. I didnt trim anything! I can take pics if you need...
Old 09-07-2007, 08:39 PM
dude... your truck is pretty much EXACTLY what i want. It looks perfect IMO. Do you have any pics with the bushwacker flares?
Old 09-07-2007, 09:28 PM
Luvnacumns's Avatar
You fellas need to post pics!!!!!
Old 09-10-2007, 03:06 PM
Well, i had the leveling kit installed on the truck today... besides needing an alignment, the truck seems fine (rides rougher... I'll be getting the long arms later). Is there anything i should watch for? i had the truck up to 60 mph on the highway, and i didn't feel any vibration... will the front driveshaft vibrate only when i'm in 4wd?
Old 09-10-2007, 03:30 PM
UnrulyNFS's Avatar
Holy smokes. That's gonna be a wide wheel. Post pics when its done.
Old 09-10-2007, 05:37 PM
solostyle1's Avatar
im 2nd guessing the flares. I have them but not installed yet. Still have to get them painted and get the stainless bolts just to break some of the black up....i have more pics of the truck if you want them...
Old 09-10-2007, 07:48 PM
UNOUNVIT's Avatar
I was also second guessing the flares on mine but i didnt have my truck outa the shop for more then 45mins after my lift and tires and was pulled over by the popo. The poor lady was a little mad i think cuz she could barly even see me. it took about 2 mins for them to try and pick me right apart.. and threaten to write me 3 or 4 tickets.. So after alot of thinking i decided to put mine on and iam still outside by flares by more then a 1" 1/2 for sure, and if i get sick of them it only would take me 30mins to take all 4 off..
Post some pics of that ride of yours, sounds like a pretty slick rig..
Old 09-10-2007, 08:56 PM
solostyle1's Avatar
the pics arent the best....i'll get closer pics of the actual lift soon..
http://i16.photobucket.com/albums/b3...ewtruck001.jpg
Old 09-10-2007, 10:17 PM
UNOUNVIT's Avatar
Looks awsome, love the black on black..
Old 09-10-2007, 10:56 PM
Lsufan78's Avatar
looks like that front axle is pulled back a pretty good bit...can you get a side shot of the front wheel??
Old 09-10-2007, 11:03 PM
Luvnacumns's Avatar
X2!!!!!! Keep us posted on how those tires wear!!!
I was wondering the same...
Old 09-11-2007, 07:35 AM
goodeyesniper75's Avatar
i have a 6" superlift with 2" spacer in front.......
Old 09-11-2007, 09:41 PM
solostyle1's Avatar
i just got hme and its dark so i'll try and get a pic tomorrow. Its just the pic itself that looks like that. The axel is inline except for it sideways. I have to get a adjustable track arm. I can turn the wheel both directions all the way and i dont rub. I think if the axel was pulled back, it would rub. But, i'll try and get the pic tomorrow.....
Quick Reply: Suspension lift with leveling kit
