Surging Tons of black smoke.
Old 09-26-2011, 02:21 PM
cjthor's Avatar
Coming home from hunting this weekend and the truck starting surging and blowing massive amounts of black smoke. I did have the cruise control on going 74 mph when this happened. I was close enough to home that I could get off the freeway and limp it back home. I seemed to do it no matter how I drove it. The one thing I did notice was that it didn’t do it all when I was in the neighborhood going about 20 mph. All the gauges were fine. Fuel pressure was at 15, which is all the higher mine reads. I do have a FASS fuel system. The filter was changed not long ago. I also put in a Timbo Apps about two years ago. The check engine light did not come on. Any ideas where I should start checking? Injector, vacuum leak, turbo.
Thanks,
Chris Thorson
Old 09-26-2011, 06:33 PM
Dixon Mark's Avatar
Did you check the turbo and piping? Sounds like you poped an intake hose.
Old 09-27-2011, 02:25 PM
drafalske's Avatar
+1. That's what mine did. Check the lower left one; mine was rubbing the inner fender and tore wide open there.
D
Old 09-29-2011, 07:29 AM
cjthor's Avatar
Thanks guys. I will check again. I didn’t see anything the first time but didn’t look that close. I did add a good dose of diesel clean to the tank. I let the truck run for about 15 minutes and then drove it for about 30 miles and it was fine.
A_Manke
10-14-2007 01:13 AM
jimlj
03-30-2007 08:32 AM
Road Traveler
03-11-2007 01:19 AM
Captain
02-03-2007 07:39 PM
Swamp_Donkey
02-06-2005 04:52 AM
Quick Reply: Surging Tons of black smoke.
