Surging
Surging
On level 5 and 6 on my Edge, I get a surging at part throttle and every once in a while a stumble on levels 3,4,5,6 with moderate throttle.
What can cause the surging?
Thanks for any input
sounds like maybe injectors "hanging up" i had the same problem and i cured it when i went to larger injectors smooth as ever now, mine would hang up for a second or two around 1100-1300 rpms.
shot in the dark maybe check your fuel filter and replace it.
good luck
good luck
Have you had the Edge updated recently?
Doubtful it's anything with your truck if it doesn't surge without the Juice turned up to levels 5 and 6...
Either your truck doesn't like it up that high, or something isn't right with your box/module.
Read and watch this thread by madhat
