Surging Comp Smarty stack
Old Aug 2, 2007 | 12:44 AM
Djasik's Avatar
I tried searching, didnt find anything can anyone point me in the right direction to fixing this? I can turn the comp off with the cruise on and it goes away but thats not very fun lol.
Old Aug 2, 2007 | 03:23 AM
kelownadiesel's Avatar
what setting are you running the smarty at?If youre using even numbers thats too much timing.
Old Aug 2, 2007 | 08:55 AM
dodgediesel's Avatar
Even numbers have no timing???? You're supose to run a timing box(Edge) with even number Smarty settings or am I crazy????
Old Aug 2, 2007 | 08:59 AM
bentwings's Avatar
If you run SW5 or greater you will get cruise surge without a load. I can run SW5 with a 7k load and it is just past the surge point in cruise. My 4.10 gears probably soften it a little however.
Old Aug 2, 2007 | 09:03 AM
Djasik's Avatar
Im running it on sw8 right now, hey its a new toy lol.
Old Aug 2, 2007 | 10:20 AM
Mike D's Avatar
My fix was to install a piece of red tube from a WD40 can into the vacuum line going to the cruise control. Not sure if the 5-speeds are vacuum controlled or not on the 99's. It worked on my auto.
Old Aug 2, 2007 | 03:02 PM
Djasik's Avatar
Ok the cruise is around the drivers side fender right? I have heard of the wd40 trick before, I believe mine is vacuum controlled.
Old Aug 2, 2007 | 04:01 PM
isbeinside's Avatar
is it a TCC surge, what are the symptoms, because it might have to do with your alt. ground wire?
Old Aug 2, 2007 | 04:07 PM
Djasik's Avatar
Nah it just does it when the comp box is on with the cruise set.
Old Aug 2, 2007 | 05:57 PM
Fishin2Deep4U's Avatar
Mine had a bad surge. That's why I sold the Smarty. It seems to affect the built auto guys that run fast spooling chargers and big sticks with higher gear ratios.
Mine surged so bad with the Smarty alone on level 3 or higher, the cruise was useless. The throttle was just too touchy.
Put the thing in my dad's stock truck, he doesn't notice a thing.
So, it depends on the setup. You have to understand what is adding fuel and when to get a clear picture of a "fix". I have been asking for help with it for almost a year and gave up.
Dave
Old Aug 2, 2007 | 11:26 PM
OOOOpss I meant to say odd numbers ,sorry.If youre on 8 thats fine.thats what Im doing and I couldnt be happier
dodgediesel
Jul 27, 2007 08:59 AM
dieselbeef
Jul 27, 2007 01:21 AM
whitestreak06
Jun 8, 2007 01:29 AM
bignastydodge
Mar 29, 2007 07:36 PM
Awall
16
Jan 1, 2007 05:22 PM
