Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
Supplies and Parts thread for WMO filtration
Old 02-26-2011, 12:52 AM
PhillyB's Avatar
I am in the process of setting up a WMO filter and having a heck of a time locating some of the parts I need.
I thought it would be nice to have a thread with links for filters, filter socks, and other expendables.
Mainly I would like to know where to pick up inline filters and the "caps" they screw into.
I have found one pretty good site. Feel free to post whatever you have. Thanks guys.
http://www.utahbiodieselsupply.com/m...elsupplies.php
Old 02-28-2011, 11:07 AM
LeviMXUSMC's Avatar
Good Site. I Need to get the plastic tanks or not sure about getting the apple seed kit. I also need to find the pumps.. Everything other than that I can get at the hardware store.
Old 03-03-2011, 11:36 AM
irocpractice's Avatar
For your basic pump,try Northern Tool .Item# 52067,$100.00
or have you been here?
http://www.journeytoforever.org/biof...ply.html#pumps
Old 03-03-2011, 03:26 PM
b4black's Avatar
Fram supply stores. They all carry filters and the adapters they screw onto. Many farms have their own diesel tanks on site and they need the equipment like hoses, nozzles, etc.
Old 03-14-2011, 02:14 PM
jesussaves's Avatar
is there a how to link or parts list need to start doing this? Once you make WVO do you need anything done to your truck?
Old 03-15-2011, 12:37 AM
Santaclaus's Avatar
Might be of interest. Mike
http://biodiesel.infopop.cc/eve/foru...1/m/2001011761
Old 04-09-2011, 03:06 PM
dadijohnson's Avatar
If you don't mind visiting a Ford site, try the alternative fuels portion of the forums on thedieselstop.com site. These guys are really into the WMO issue. There is a lot of info, you can read for days and not cover it all. Most of the guys setups are low cost DIY. The popular resolve for the pump issue is to use a small block chevy oil pump (SBC) for moving the oil, this is what I use. The sbc pump will pump any weight including grease. Power it with Gas or electric. On this site you will find the details on how to set the pump up. I use an electric drill 1/2" 10 amp that I bought at HF for $32.00, this way I can have variable speed as well as reverse if needed. Also you will find the ratios for mixing (RUG) regular unleaded gas with your oil to produce the viscosity match to diesel.
Last week I picked up 10 55 gal. drums of WMO (real clean stuff) from a mint farmer and it burns great in my first gen.
Check out the above site, you will find answers for all your WMO questions.
Dan
Old 06-04-2011, 11:37 AM
dguru's Avatar
I use cheep 1 micron RO (reverse osmosis) water filters. You can get them for under a buck each on ebay. The filter container is about $15. I use a small air operated diaphragm pump pushing into two of these filters in series. I regulate the air to the pump to about 10PSI to keep flow rate slow. The pumps can be found in old soda fountains.
I let a full drum of unfiltered oil pump through the filters to the other. I turn off the compressor and walk away. It will stop pumping about the same time the oil runs out of the dirty drum. Plastic 55 gal drums are cheep. I also will let the drum sit in the sun for a few weeks before filtering to check for water and let a few gal in the bottom of the drum go to a recycler.
You could gravity feed the filter if you build a stand for your dirty drums but it is more trouble.
easinc
22
03-31-2011 11:22 PM
PADuallyBoy
28
01-28-2009 04:44 PM
RCinMesa
04-30-2008 09:32 AM
jeepsuck
04-12-2006 04:08 AM
ViperSBT
11-01-2003 10:48 AM
Quick Reply: Supplies and Parts thread for WMO filtration
