Superchip and egt's
Old 03-02-2010, 08:12 PM
John Beere's Avatar
Superchip and egt's
With my superchip i'm running 1400 degrees and 43psi at 3/4 throttle, when i mat the go peddle the wastegate opens, drops the boost to 25psi and the pyro pegs. Would a boost fooler help with the egt's?
Old 03-04-2010, 04:35 PM
LReiff's Avatar
Sounds like your waste gate is hung open...
Old 03-05-2010, 08:20 PM
John Beere's Avatar
If the wastegate was stuck open i wouldn't make that much boost. I'm just thinking if the wastegate stayed closed i would stay around that 1400 degree mark. I'm getting close to boost pressures that would require head studs and hoping the boost fooler wouldn't push me over that line.
Old 03-06-2010, 03:34 PM
Silverram03's Avatar
What kind of turbo? If its stock your on borrowed time with that much boost.
Old 03-07-2010, 12:17 PM
John Beere's Avatar
it's the stock turbo.
R.T.D.H.S.P.
06-21-2007 09:05 AM
DieselNoob
04-19-2007 08:27 PM
garybg1
01-16-2007 08:46 AM
cyclopshotrod
03-21-2005 12:43 PM
Quick Reply: Superchip and egt's
