Sudden pulling to right
Old 07-09-2008, 08:42 AM
hopak's Avatar
Steering is pulling to the right all of a sudden on roads where it never did this before. I replaced the front shocks. But can't think of any other changes. Tire pressure is ok. Would worn ball joints on the right be a possible cause.
Old 07-09-2008, 09:04 AM
seahawkdodge's Avatar
I had a unit bearing go on my 98, and had similar problems. When I put the truck up on stands, I could move the tire in and out a bit too easy.
A couple other things to check, would be your steering arm ends, and your tie rod ends.
Ball joints are a possibility.
Old 07-09-2008, 09:11 AM
Hillcountry's Avatar
ALso check your track bar, and depending on the miles, the steering box could be loose. I recently replaced the track bar and installed a DSS steering stabilizer and the problems you describe were solved.
Old 07-10-2008, 02:48 PM
dozer12216's Avatar
Perhaps a caliper is starting to hang up. Check for overheating on right brake. Replace calipers in pairs. The rears have some issues also but just overheat generally. You did not say pulled with brakes applied, did you?
hulmule
03-10-2010 10:42 AM
mullercarl
Competition / Pulls / OffRoad
45
03-19-2007 10:10 AM
j-fox
10-30-2005 05:24 PM
Jmac
07-22-2004 05:09 AM
Ram lon ON
05-10-2004 07:17 AM
Quick Reply: Sudden pulling to right
