Sudden MPG Drop
Old 04-05-2011, 03:46 PM
nvrenuf's Avatar
Sudden MPG Drop
Ok, I'll admit this is a knee jerk, panic post...
I have an '06 Megacab 4wd 6spd w/ 53k miles - original owner, always totally stock.
I'm due to fill up and checked the trip odo "just because" and noticed a dramatic decrease. I typically get 450+/- miles between fill ups, today I'm down to ~1/8 of a tank (usual fill up time) and only show 36x miles. Since around 12k miles the truck has consistently averaged 15.5 mpg (hand calculated).
A month ago I changed from the original 265's to some Hankook 295's. I knew I might see a small drop in mpg's but this much?! I've checked via phone GPS and my speedo is now off by 3 mph.
I am due for a fuel filter as I change it around every 10k. I consistently buy my fuel from the same place and have never had any contamination issues.
Is there anything I should look for or check? I'm worried because I've got to take it on a 600 mi trip in a couple of weeks. Help!
Old 04-05-2011, 04:22 PM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
Brother it ain't the fuel... I put on a new set of 6 Pirelli tires and my mileage dropped almost 3-4 mpg! Yep, I had a set of General Ameri-Trac's on there that had over a 100k miles on them and got great mileage but the extra friction/traction kills your ease of rolling. It'll get better but it'll take some time. Just have to grin and bear it I guess. LOL
Old 04-05-2011, 04:35 PM
nvrenuf's Avatar
Well, that's good to hear (sorry for you). I can deal with mpg loss due to the tires. I've read so much about injector failures and older truck lift pump failures I tend to be a little jumpy.
Thanks!
Old 04-05-2011, 04:37 PM
AggieJustin's Avatar
Your speedo is off by 3mph at what speed? You can use that to calculate how far off your odometer is to get a true hand-calculated mileage reading.
Old 04-05-2011, 04:54 PM
nvrenuf's Avatar
I've checked it at speeds ranging from 35-50mph and it seems consistant across the board. I haven't been on the interstate yet to check it at 70/75mph.
Old 04-05-2011, 05:06 PM
rockcrawler304's Avatar
Did you take this difference in tire size into account when you figured your mileage? With the taller tires, you drove more miles than your odometer shows.
Old 04-05-2011, 05:33 PM
It's easier to check at 70 since you'll see a bigger difference. It definitely won't be consistent across the range. The faster you're driving, the more off it will be.
If you figure 3mph off at 35mph, that's 8.6%. So 360 miles on the odometer would really be 390.6.
But if you're 3mph off at 50mph, that's only 6.0%. So 360 miles would be 381.6.
Old 04-06-2011, 09:27 AM
xyzer's Avatar
I used my Smarty to adjust the odo not the speedo. Found a slight difference between the 2. With the odo set correctly the speedo reads 60 and your going 63ish.
Old 04-06-2011, 09:48 AM
That's the first I've heard of that situation. I thought the odo and speedo were driven from the same source. I use my Smarty to update my tire size which corrects both the odo and speedo.
Old 04-06-2011, 11:02 AM
How exactly can you change the odometer with the Smarty? Only thing adjustable on the Jr. is the tire size.
MtnDodge
04-08-2013 08:19 AM
markpp
04-28-2009 06:35 PM
Ron R
09-16-2008 11:09 AM
dieseldel
24
07-28-2003 12:30 PM
DieselDaze
02-02-2003 09:02 AM
Quick Reply: Sudden MPG Drop
