Stumbling problem
Old Apr 13, 2006 | 07:17 PM
Bama_Dude's Avatar
going back to d-max
.I think after doing a search I may have a fuel issue.I noticed my truck hesitating on takeoff .It will stumble leaving from a dead stop.The engine gets loud and the rpm increases very slightly.It sarted a while back and only did it every now and then.Its doing it more often now.It runs fine at wot.I checked for codes but have none.I did change the fuel flter a week ago.It will do it sitting still in park and idleing also.You can hear it start raddeling for a second or two.Any thoughts?
Old Apr 16, 2006 | 08:37 AM
Bama_Dude's Avatar
Thanks for all your help,Im trading it in on a real truck,the duramax.
Old Apr 17, 2006 | 09:24 PM
SafeHarbor's Avatar
Hi, Bama_Dude,
Ever heard of "Bump" on a forum?
Old Apr 18, 2006 | 12:20 AM
Bama_Dude's Avatar
Yea ,but I thought I would try something a little catchier. still did,nt get any help.You think bump might work?
Old Apr 18, 2006 | 12:21 AM
Bama_Dude's Avatar
bump,bump,bump
Old Apr 18, 2006 | 03:47 AM
Rauschbo's Avatar
Sounds like you're getting intermittent fuel-starvation? Anything show on your gauges, and did you have the same issue before the Quad?
Old Apr 18, 2006 | 07:24 AM
MikeyB's Avatar
Try removing the Quad and see if the symptom is still there. Also could be the lift pump is going south or there's a problem with the CP3 pump.
MikeyB
Old Apr 18, 2006 | 01:37 PM
GrandpasRam's Avatar
Bama Dude, I had the same problem on my old '03 at 27k miles. No one else had reported anything similar at the time, so the dealer and Star had no clue. After replacing the lift pump, all six injectors, and not curing the problem (this was all under warranty), I noticed and told them that the fuel pressure would drop just before the stumble, and that told me that perhaps the fuel return valve on the CP3 was opening when it should not. They replaced the CP3 and the problem went away. This sounds just like the symptom you are having, and I suspect that the fuel return valve on your CP3 is defective.
Hope this helps.
Old Apr 18, 2006 | 06:58 PM
SafeHarbor's Avatar
See Bama_Dude? Three bumps, three answers. It works!
Old Apr 18, 2006 | 07:39 PM
Spooler's Avatar
Some days are better than others with getting replies. Most everyone works. WORK,WOR,WORK. That is all we do sometimes.....
Old Apr 18, 2006 | 09:47 PM
Bama_Dude's Avatar
Thanks alot guys I thought there for a while you were ignoring me. I Have the problem with or without my quad box.I guess I need to get it to the dealer.I just cant give up my truck for a week.I tried their free oil changes for a while but they keep it all day and I work out of mine.Thanks again.
Old Apr 19, 2006 | 12:05 AM
dodgezilla04's Avatar
mine would knock and shake at idle in a parking lot, then it progressed to doing it while driving. happened 3 times this weekend, then she wouldnt start. finally got it started and home, took 5 minutes to get it restarted, during the time it wouldnt start, i couldnt hear the LP running so I am replacing it with the BD kit. I will start on it tomorrow night. hopefully that is the problem, will keep posted.
Old Apr 19, 2006 | 08:16 AM
My trucks have all been bone stock except for guages and the Scotty III air intake. Obviously, Star did not want to replace the CP3 without being sure, so they ran a tank of fuel with 2-cycle oil added to it to see if the return valve was sticking, and as long as there was a high enough concentration of oil in the fuel, no stumbles occurred. For their purposes it proved the CP3 was defective, and they replaced it. Hope this all helps when you take it to the dealer.
Old Apr 19, 2006 | 09:15 AM
MikeyB's Avatar
Hmmm. Maybe it's a good thing that I'm mixing TCW-3 in with Power Service Diesel Klean.
MikeyB
Old Apr 20, 2006 | 09:06 AM
MikeyB
I always used a lubricity additive too, but the problem required a much higher concentration than should have been necessary. During the time the 2-cycle oil was running through, the truck was blowing large volumes of black smoke that prevented me from towing my 5th wheel 'cause I didn't want to soot it up, but the smoke problem turned out much later to be a boost leak (that is another story entirely).
Chesapeake
Nov 29, 2006 02:44 PM
tacohat
Jul 5, 2006 12:31 PM
dslsmoker
Nov 19, 2005 03:55 PM
alltimelow1
Apr 6, 2005 07:28 PM
99 cummins
Oct 30, 2004 09:33 PM
