stripped torque converter bolts
Old 07-19-2007, 12:24 AM
maddog1927's Avatar
Canadian tranny guy said to torque flex plate to torque converter bolts to 50. Apparently he meant 50 Newton Meters, not 50 Ft. #’s. I tried 50 ft. #’s. Bolt is stripped. I am assuming that the fix it to try to tap out to a slightly larger bolt, any advice?
FYI service manual for the ’06 says 35 Ft #’s
Old 07-19-2007, 07:07 AM
jpherr's Avatar
You might could use a heli-coil.
Old 07-19-2007, 08:05 PM
badme's Avatar
tap to bigger size or heli-coil will work, BUT be careful not to damage the converter by tapping to deep.
fastlane
06-23-2010 10:38 PM
CG98x
13
11-08-2007 09:30 PM
xzaq103
06-25-2007 10:27 PM
94/300k2500
10-05-2006 01:48 PM
boostedte37
07-20-2005 07:56 AM
Quick Reply: stripped torque converter bolts
