Strange idle
Old 01-20-2010, 12:41 PM
roccoboost's Avatar
Strange idle
Recently when sitting at idle the truck seems to have a slight "lope" to it. Was idling smooth as glass before. Also seems slightly down on power, but no boost gauge hooked up to verify if there is a drop off. Im not seeing any extra smoke when I am idling or at full throttle. The truck is stock, besides a 4" exhaust and automatic. Any ideas what it might be.
Old 01-20-2010, 12:58 PM
93flatbed's Avatar
A weak lift pump, or air getting into the supply side of the fuel system. A fuel pressure reading would be very helpful for diagnosis.
Justin
Old 01-20-2010, 01:35 PM
roccoboost's Avatar
I have a new piston lift pump to be installed. The current lift pump appears to be the original, and probably is a little on the tired side. I was planning on hooking up a fuel gauge when I switched LP's. I will have to double check the hose connections back at the tank to make sure they are ok as well.
Old 01-20-2010, 01:42 PM
93flatbed's Avatar
Well since your doing some supply work, you may want to just upgrade the pickup side to 3/8". But thats just a suggestion.
Make sure the lift pump is low pressure, or plan on doing a regulator.
Good luck
Old 01-20-2010, 02:25 PM
dodgetrucker75's Avatar
strange, my 75 did this the other day, started it and it sounded like a cammed big block gasser, did this for a minuete or so and then everything was normal, never happened before, and i have 3/8 gravity fed lines,so no chance of bleed off, and good pressure on the gauge...
Old 01-20-2010, 03:44 PM
It's air. You have a leak somewhere.
Old 01-20-2010, 05:02 PM
roccoboost's Avatar
Is it possible that the air leak could be caused by the lift pump some how? Are there any places in particular to check for air sneaking in? I replaced the old rotten leaking fuel lines a few months back with rubber lines from tank to pump. One long piece for supply and one for the return with no breaks in between.
Old 01-20-2010, 08:01 PM
93 12v's Avatar
How do you find an air leak anyway? Because I have a similar problem. Lopes a little in gear, slight ping/knock in park. It's between this and a weak injector, I think.
Old 01-20-2010, 09:01 PM
93flatbed's Avatar
The way I go about finding an air leak is to apply air pressure to the tank and look around the fuel system for fuel to start coming out. Wrap a shop rag around an air blower and put it in the fill neck of your tank.
Good luck they can be a chore to find.
Old 01-20-2010, 09:59 PM
93 12v's Avatar
Thought so. Do I need to limit the air pressure so as not to damage the LP or IP? My air is set at 120. Thanks.
Old 01-21-2010, 04:55 PM
Less than 5 psi. You don't want to split the fuel tank!
Old 01-21-2010, 06:58 PM
93 12v's Avatar
That would be a disaster! Thanks Dave!
Awall
01-24-2007 05:41 PM
Copenhagenjunkie
10-31-2006 01:52 PM
docauto
24
02-06-2006 10:50 AM
slimchase
02-13-2003 05:20 AM
AFMSgt
11-13-2002 02:29 PM
Quick Reply: Strange idle
