View Full Version : Straight Pipe
kennywayneracing
11-15-2002, 06:36 PM
A while back there was a post mentioning a factory Dodge test piece that eliminated the cat/resonator. If someone could repost that part number or direct me to the right thread I'd appreciate it. Thanks.
Michael Az
11-16-2002, 02:10 PM
I think that Geno's Garage has them. They are on-line<br>Michael
John_P
11-16-2002, 07:39 PM
kennywayneracing:<br><br>Welcome to the website!!<br><br>I believe that was me that posted about the Dodge<br>Diesel "Test Pipe" awhile back. This pipe goes in<br>place of where the factory cat goes. Dodge <br>Technicians use the "test pipe" to check the<br>cat to see if it is plugged or bad.<br><br>The part number from Dodge on this "Test Pipe"<br>is: #52019170AB. When they order it it will be<br>listed as: "Exhaust Pipe"; at least mine was!<br>As I recall it cost around $49.00.<br><br>Hope this has helped you some.<br><br>---------<br>John_P
kennywayneracing
11-18-2002, 12:25 PM
Thanks guys. I already have the Geno's kit installed and needed the part number John listed in order to remove the cat/resonator section. I'll call in to the local Dodge shop and see if they can find a listing for that "test piece".
