straight pipe
Old 10-18-2006, 10:34 AM
T-REX's Avatar
straight pipe
I have a new 06 dodge ram 3500 6 speed cummins, I want to straight pipe it.
Should i leave the cat in or take the cat and muffler out ?
Old 10-18-2006, 10:49 AM
mitternocht's Avatar
Leave the CAT on and run a strait pipe from the CAT back. That is how mine is and it sounds good. It is illegal to remove the CAT anyway. Around here they have inspections, it be too hard to keep taking the CAT on and off. From what I’ve heard they are too noisy w/out the CAT and make no more power in stock form.
Old 10-18-2006, 11:11 AM
T-REX's Avatar
is it still loud by just taking the muffler off
Old 10-18-2006, 11:36 AM
P.J
P.J's Avatar
Loud(er) that is for sure.
Funny, it is identical at highway speeds (in the cab that is).
For me,...... it is borderline TOO loud, but I'm sure I'll get used to it, I am very happy with it compared to stock.
Old 10-18-2006, 02:58 PM
Pooter's Avatar
Ditch the cat!
Had mine straight piped with just a 4" pipe, left the cat for about two months....
Cut it off a month ago for 5" straight pipe all the way back(4" down pipe, no cat, 5" from downpipe back)
Sounds awesome!
Old 10-18-2006, 03:07 PM
XLR8R's Avatar
I'm not a big fan of straight-piping, though it certainly is the cheap way to get a manly exhaust!
I TIG-welded a 4040L to the downpipe, and welded the cat-shell on the back of that with a turndown exiting just past the cab so you can't see inside...
Sounds very good.
Old 10-18-2006, 09:17 PM
TurboTed's Avatar
The Magnaflow droned badly under load in my brother's 03. I'm thinking of leaving the cat(so don't delete this post ), and using the 30" Magnaflow on my 05. Will it still drone under load, or will the cat prevent that? (I had the biiiig Nelson on my 03, and it had no drone, but was a bit quiet.)
Old 10-18-2006, 09:26 PM
rustyshakelford's Avatar
i cut the muffler off and replaced it w/ some 4". easy and cheap. i wouldnt take the cat off just for warranty reasons and it still sounds good. as it was stated earlier it sounds almost the same at highway speeds so thats nice, but mash the motor w/ the windows down and shes sounds great
brett
Old 10-18-2006, 09:31 PM
12valveford's Avatar
take you truck down to the exhaust shop
cut off the cat
use a air hammer to knock out the guts
reinstall
the dealer never has to know
Old 10-18-2006, 09:33 PM
TurboTed's Avatar
From what I've read, it seems that the straight pipe with cat has a great sound, but some report drone under load, which is what I want to avoid.
Old 10-18-2006, 09:43 PM
panama's Avatar
Mine has a drone to it under load but any other time sounds nice. Too avoid some of the drone you can put a tip that extends past the bed to avoid it from resonating back up. Seems to quit it down quite a bit untill you get up next to something.
Old 10-18-2006, 09:49 PM
schaef_12's Avatar
If you straight pipe it you will have a drone under load. Around 1800-2000 rpm tends to resonate the sound throught the cab, windows up or down.
Old 10-18-2006, 10:09 PM
TurboTed's Avatar
Does anyone have the 30" Magnaflow with Cat? If so, does it have the drone under load?
Old 10-19-2006, 04:31 AM
Dodgezilla's Avatar
I just got the RPM Outlet muffler delete pipe which leaves the CAT in place. This thing sounds great. If you ever heard a straight piped truck and thought "Man, that sounds awesome but it's just too loud!" Then this is for you. Same exact tone but only half as loud. Louder than most mufflers but quiet compared to a true SP truck. Some mufflers give these trucks a strange sound but not this .......
Old 10-19-2006, 08:04 AM
TurboTed's Avatar
I like what your saying dodgezilla, but as panama and some others indicated on other threads, they get a drone under load. So- anyone tow with the magnaflow and a cat?
Quick Reply: straight pipe
