Storing my truck?
Old 11-04-2008, 07:47 AM
ram 2500's Avatar
Storing my truck?
I am going to be storing my truck this winter is there anything that I should do to it????
Old 11-04-2008, 08:44 AM
Jeff in TD's Avatar
I suppose I'd put a battery tender on it, wash and wax it and clean the interior, and probably put fresh oil and a filter in it, if it is close to being due...
How long do you think you will be leaving it sitting?
Old 11-04-2008, 10:07 AM
snoyes's Avatar
Full tank of diesel as well.
Old 11-04-2008, 12:20 PM
ram 2500's Avatar
4-5 Months mabby eaven longer.
Old 11-04-2008, 12:21 PM
ram 2500's Avatar
Should i put anything in to the fule to keep it from jelling??
Old 11-04-2008, 03:56 PM
Jeff in TD's Avatar
I'd assume the fuel where you are now is winterized?
You could put some powerservice or whatever in, an like Ram2500 said, top off the tank so you don't get condensation in there.
Old 11-04-2008, 05:03 PM
johnh's Avatar
Originally Posted by ram 2500
Should i put anything in to the fule to keep it from jelling?? It gets down to -45 at times up here.
if you're not going to be driving it, it doesn't matter if it jells, just fill it up
Old 11-04-2008, 05:59 PM
Coolhand37's Avatar
I always stored mine for the winter up here in NY (close to seven months )
Just do as mentioned above by filling up the fuel tank. I pulled my batteries out and periodically charged them through the winter. I always changed the oil & filter as soon as I got it out too.
This always worked good for me.
Old 11-04-2008, 08:28 PM
dozer12216's Avatar
Change oil before storing. Moisture/acids in oil will work on bearings, ect while in storage. Good ideal to get tires off ground and reduce tire pressure. make sure antifreeze in good order. Clean and wax vehicle as others sugggested. Clean interior. Is brake fluid in good condition along with rest of fluids. Take batteries out and have someone charge every other month. JMHO
Old 11-05-2008, 07:28 AM
paroxysym's Avatar
what about if youre storing it a month at a time? hate to hi-jack but would the batteries be good if sitting for a month? i do plan on topping the tank off..
Old 11-05-2008, 03:06 PM
Jeff in TD's Avatar
Personally, I wouldn't worry about it if it were only for 4 weeks...
Old 11-05-2008, 03:22 PM
airforceivan's Avatar
What about THREE years.
Old 11-06-2008, 03:20 AM
beretzs's Avatar
I would not worry about the truck sitting for an extended period of time. The guys have hit all the high points. I have stored my vehicles (diesel and gas) for up to 11 months while deployed. I usually undid the battery terminals (both batteries) and made sure it had a topped off tank of fuel. I have not had trouble ever coming home and reattaching the batteries and firing the truck up. I would make sure it is parked away from a field or grass since little critters like to make nests, but just check out your intake when you get the vehicle ready to drive again. I would rather let my truck sit for one year than to have someone start the truck for 15 minutes a month. Doesn't charge the batteries enough from starting and doesn't get it hot enough to burn off anything. You will be fine. I have stored vehicles alot while in the Marine Corps and until I got married, nothing catastrophic has ever happened to mine. Scotty
Old 11-06-2008, 08:58 AM
ram 2500's Avatar
Thanks for all of the feedback!!
Old 11-06-2008, 09:34 AM
hivoltage's Avatar
You could just ship it to me,I'll keep it warmed up for ya! I'll even park it in the garage at night!
Quick Reply: Storing my truck?
