stock receicer ?
Old 03-19-2008, 09:32 AM
stealman1's Avatar
stock receicer ?
The stock receiver hitch on a third gen truck is rated for how much weight? And how much with weight distribution hitch? Can I tow 10,000lbs. with the stock receiver and weight distribution?
Old 03-19-2008, 09:51 AM
TonyB's Avatar
What year are you asking about? IIRC, my '06 is good for 12k.
Tony
Old 03-19-2008, 09:58 AM
stealman1's Avatar
I have a 03.
Old 03-19-2008, 10:12 AM
staarma's Avatar
Here is the sticker on my 04.5.
Old 03-21-2008, 10:24 AM
stealman1's Avatar
How many of you exceed the ratings on the stock hitch? Do I need a class V? Im getting a toyhauler with a dry tung weight of 1050lbs. I will get weight distribution, but even with that the receiver is only rated to 1200lbs. I can see having a loaded tung weight of maybe 1400lbs. Is the stock receiver enough?
Old 03-21-2008, 10:40 AM
supr's Avatar
I think th sock receiver is class IV. I have occasiosionly gone 12k, without an equalizer, not often. I would certainly go Class 5.
As Clint Eastwood would say, "Do you feel lucky, punk?".
At any rate, why gamble on an expnsive TT with an underrated hitch?
From what people have posted, I would also get a Hensley Arrow, or something equal.
I think for over 10k, a Fiver makes a lot of sense. There are real needs to stay with a TT, for some.
Good RVing!
Old 03-21-2008, 12:13 PM
staarma's Avatar
Toy haulers have higher tongue weights for a reason when they're empty. It's so when you load the toys in the back the tongue doesn't get too light. The axles act as a fulcrum. Once you load your toys behind the rear axles the tongue gets lighter by design. At least that's the way my Weekend Warrior works.
Old 03-22-2008, 01:39 AM
TexasCTD's Avatar
I would add a Class V receiver just for the added safety margin. I too, felt like the stocker was on the weak side. I never had a failure with it, but I feel alot more confident in the strength of my Putnam XDR. http://www.trailerhitches.com/traile...s5xdrhitch.cfm
Old 03-24-2008, 10:47 PM
Equalizer 2's Avatar
I noticed on the link provided by TexasCTD the info stated drilling required. I put the XDR on my truck and it was a NO DRILL install, in fact it advertised as a no drill install.
You should probably get the ball mount and ball from them as they have the highest rating of any I have seen so far.
Old 03-25-2008, 12:54 AM
TexasCTD's Avatar
Steve I was looking at the link I posted again....and I don't see where it says drilling required. I don't recall doing any drilling on mine either. http://www.trailerhitches.com/images/pdf/PT187.pdf
We did have to cut off the OEM receiver hitch from the OEM crosstube however. That took a little bit of work. But definately worth it!
Old 03-25-2008, 07:22 PM
mmurray's Avatar
From the link above...
Weight Capacity: 15000 lbs
Finish: Black Matte
Installation Time: 60 minutes
Class: 5
Tongue Weight: 1500 lbs
Weight Distribution: 16000 lbs
Installation: Drilling Required
Hitch Opening: 2 inch
Brand: Putnam
Old 03-25-2008, 08:17 PM
RAF
RAF's Avatar
My truck is a 99. I have the XDR and tow 13 - 14,000 with pintle hook. No problems.
Old 03-26-2008, 12:29 AM
TexasCTD's Avatar
http://trailersnhitches.com/putnamcart/25211.html
MMurray, I missed that in the link. Thanks.
Here is another link......to the same hitch. It says no drilling. I think that was a typo in the ad from Trailerhitches.com
Also here is an old thread by Pourin Diesel where he installed the Putnam XDR on his sled pulling truck. Pics etc. Very stout. https://www.dieseltruckresource.com/...d.php?t=100590
Old 03-26-2008, 10:04 AM
CTD NUT's Avatar
Man, after seeing how similar the 3rd gen XDR for use with factory receiver is compared to the Superhitch from Torklift, it makes me even wonder more why it is nearly 3 times as much money as the XDR. I'm tempted to get an XDR and just modify it to include a 2nd ball mount location below the original so that I can use a camper extension.
Old 03-26-2008, 11:00 AM
mmurray's Avatar
No problem... Most of that type of info is plugged in by some tech guy who doesn't know much about the product...
Typo's are easy to make...
Quick Reply: stock receicer ?
