stock pinion factor
Old 05-01-2007, 09:10 AM
GSW
GSW's Avatar
stock pinion factor
Need to get my 04 reset for stock tires (265-70-17) at the dealer. Before I go in there I need to know what the stock pinion factor is so I can make sure it's done right (you know how it is).
Or, does the scan tool have a fool-proof "return to stock" option that would make it all simple? Thanks in advance.
Old 05-01-2007, 10:15 AM
jkitterman's Avatar
You have to post your gearing. 3.73?
Old 05-01-2007, 10:26 AM
GSW
GSW's Avatar
Sorry, yeah 3.73. 4x4 with 265/70-17 Michelins stock.
Old 05-01-2007, 11:38 AM
elirandolph's Avatar
there are tire selections in the scan tool that they use. Just tell them to put on the tire size. You have to manually input revs per mile if your tire size is not listed in the tire selection window. 265 70 17 is definitely in that listing.
Hope this helps
Old 05-01-2007, 01:46 PM
GSW
GSW's Avatar
Hope this helps
Thanks. I thought only 06 and newer went by tire size and that 04s were strictly revs per mile. I'll give it a shot and see what happens.
Old 05-01-2007, 02:27 PM
RamWheelsBy4's Avatar
The BFG Rugged Trail stock 265/70R/17 tires are 661 RevsPerMile.
The Michelin LTX/x 265/70R/17 tires are 657 RevsPerMile.
This is manufacturer spec for the Dodge specific tire.
Old 05-01-2007, 02:43 PM
GSW
GSW's Avatar
Thanks for the help!
ataboy9026
12-11-2005 03:55 PM
BLACKDODOGE
12-07-2005 09:33 AM
hognutz
11-28-2005 12:16 PM
CSAGrey1
09-14-2005 07:39 PM
Geographic Void
13
09-08-2005 04:00 PM
Quick Reply: stock pinion factor
