Is stock clutch strong enough???
Old 05-18-2008, 06:54 PM
Toy Hauler's Avatar
Recently i just got back from Moab pulling my Jeep on a 16ft trailer and a 3,000 lb camper,I have an 06 Dodge with a six speed and it's powerhouse is a Cummins a few times on take off it seemed as if the clutch was not strong enough to support this kind of takeoff,my question is when time to change shoud i put something stronger in it clutch wise.?.......Toy Hauler
Old 05-18-2008, 11:00 PM
SundayMoney's Avatar
How badly have you beat on the stock clutch?
How much power have you added?
Pulling my fifth wheel I'm at about 19k lbs combined. I haven't had any issues in the last 17k miles.
My clutch is holding up fine.
Old 05-18-2008, 11:11 PM
Sandaholic's Avatar
It should be plenty strong enough? What size tires are you running and what gears do you have in it? Also what is the gcvw of your setup?
I have 35's on with 3.73 gears. I'm about 22,500 and I take off just fine. I think the G56 you have is geared lower than the NV5600 (could be the final drive ratio I am thinking of?) so unless you are running bigger tires than I am I don't see an issue. Like was said previously have you beat on your clutch pretty bad?
In the end though we could all use a super stout clutch so if you have the dough go ahead and get one!
Old 05-19-2008, 04:11 AM
Moose10's Avatar
Sure.
What a strange thread
Old 05-19-2008, 05:19 PM
Toy Hauler's Avatar
It is all stock even the tires and only has 31000 miles on it.Everything seems to work well when it is rolling plenty of power it's just the takeoff seems to be like the clutch is already let out just before it rolls
Old 05-20-2008, 04:35 AM
robert chilton's Avatar
Sounds like the dual mass flywheel is hating life.
Old 05-20-2008, 08:21 AM
cmac's Avatar
might be a dumb question but i will ask it anyways...... what gear are you taking off in??
Old 05-21-2008, 08:33 PM
CoastalDav's Avatar
My original Clutch went 180,000. I thought I beat it pretty good also. Lots of towing.
Dave
HOHN
02-28-2014 03:20 PM
Need95-00CTD
15
11-15-2007 11:33 AM
Boatnik
08-05-2007 09:09 PM
PG4x4
05-04-2007 02:23 PM
BigBlackDodge
01-09-2003 05:45 PM
Quick Reply: Is stock clutch strong enough???
