Stock Box Air Filter
I'm curious, I got one of those Amsoil eA air filters about 2 1/2 years ago, been blowing it out every once in awhile but noticed within the last few months, my indicator thingy was getting pulled down, sometimes about half way down. When I saw that, I thought "Gee, I just blew it out" but I got curious. Went to Kragen, picked up a good 'ol basic Fram air filter, stuck it in and since I did that, the filter gauge ain't budged! Was my Amsoil that bad?
Those air filter indicators are not that reliable. I can pull mine half way down with a brand new filter.
If you have a boost gauge use that, when you start noticing the max boost level isn't as high as it used to be it's time to change the filter.
MikeyB
MikeyB
I had the same issue with my Amsoil dropin. I think the indicator is working correctly. It did not pull down when new, but started pulling down after 25K or so. Even though I cleaned it on a regular basis, there is no way to get all the dirt out. When it started pulling halfway on a regular basis, I stopped and dropped in a Napa filter. The minder is not moving again.
One other note, when I changed the filter I noticed the top of the airbox was harder to fasten. Even though the filter may still be usable, I feel the gasket starts deforming and may not seal as well as new. So for that reason alone I would not run any filter in the stock box for an extended period of time.
1stTimeAround
07-09-2012 09:24 AM
jbham
01-26-2009 09:20 PM
Wildhog
13
08-04-2008 08:07 PM
Grocery Getter
06-29-2007 01:31 PM
Pumperdude
12-03-2003 12:28 PM
