stock and smoking
Old 09-14-2008, 05:46 AM
reubone1's Avatar
stock and smoking
abot 4 months ago my truck started smoking upon start( sometimes blueish, sometimes whiteish) up and smoking upon acceleration(black). now my truck is compleatly stock with 309,000 miles on it. you guys with your great trucks have got me wanting to upgrade but can't see doin that till i know whats up with the truck first. thanks for any help
Old 09-14-2008, 09:47 AM
Number47's Avatar
blue smoke is oil white smokes is from timing issue or radiator fluid and i'm sure you know what the black smoke is. Try Cleaning/replaceing your Intake Air Temp Sensor and your Manifold Absolute Pressure sensor and reset your APPS
Old 09-16-2008, 07:15 AM
reubone1's Avatar
will do this afternoon. yeah i wouldn't mind the black smoke if i knew it was due to a mod but its still stock. i'll post my results, thanks
Old 09-17-2008, 08:26 PM
dozer12216's Avatar
I suspect a set of injectors are in the works for you. Have codes read and make sure lift pump is producing adequate pressure. VP44 is at high risk with bad lift pump. Read my other posts for injector story.
Old 09-18-2008, 06:18 AM
reubone1's Avatar
thanks for the help guys. temp sensor was cleaned but can't tell if it helped or not. also can't find my map sensor. they must hide it well or i just can't see it. injectors........ could be a blessing in disguise. lift pump was replaced 3 months ago and still sounds good. i suspect my ip. also this is wierd. at interstate speed i can maintain 70mph just find but try to maintain 80mph it will suddenly lose power and fall back to 65mph. then if i lift throttle for a second or two full power resumes as long as i don't get on it hard. in the mornings it opperates at half power at best for a while then suddenly full power!? i'm so confused but i live this truck so i won't give up yet. must be hard headed
Old 09-18-2008, 07:13 AM
hogwild's Avatar
I would check fuel pressure before you kill Ip.
Old 09-18-2008, 08:12 AM
nickg's Avatar
sounds like the VP is already done in, signs of dead pedal and 1/2 power till warmed up,and if thats the orginal VP I think you more than doubled the life expectancy of the average VP.
again have the codes pulled.
also a LP might sound like its working and definately fail in 3 months,(esp a stock LP) unless you have a gauge your only guessing as to if it works or not.
Old 09-19-2008, 06:32 AM
reubone1's Avatar
well got the codes pulled and got the death codes. guess the mods will have to wait. deffinetly need fuel pressure gauge for lp though. good idea. tell me guys are industrial injection's and bd performance pumps worth the extra price? the plans i have for my truck are as follows. fire rings or beefed up head gasket, quadzilla xtz and smarty revo, 110 or 150 injectors, upgraded single to become twins in the feture, bhaf, 4" exhaust with 6" stacks with hush power muffler or good resonator( to kill drone ), upgraded intercooler and zz custom fabrication intake manifold, all tranny work and controllers to be done by suncoast. could all be a pipe dream but thats what i'm shootin for
Old 09-20-2008, 01:46 PM
Western Rammer's Avatar
I'd go with the FASS 150 gph pump. Even more so now with their new warranty.
Randy.
strokethis3500
03-16-2007 08:52 PM
roughstock
03-26-2006 02:30 PM
BlueOxD350
01-11-2006 11:20 AM
Bad Ramer Jamer
12-09-2005 06:56 PM
DodgingTools
33
06-10-2005 01:59 AM
Quick Reply: stock and smoking
