stock 91 12v, cheap mods???
Old 11-08-2010, 08:09 PM
Racing_Joe66's Avatar
what cheap at home mods can i do to my stock 91 12v auto to get more power? it barely has power to pull my camper.
thanks
Old 11-08-2010, 08:30 PM
Lil Dog's Avatar
This should get you on the right track.
http://www.dodgeram.org/tech/dsl/mor...r/Power_ve.htm
With just pump adjustments to my 93, I got 215 RWHP with it. Should be fine. I maxed out the fuel screw, shaved the AFC washer, turned the AFC pin to full advance and bumped the timing.
Old 11-11-2010, 01:52 PM
Thanks for the link, its greatly appreciated!
What fuel pin do you guys suggest as for the best and cheapest. Also the same for injectors and a newer turbo for more boost and quicker spool up for take offs while pulling a load.
this truck will be used to pull my 32' camper and enclosed race car trailer around. so i am not wanting to go overkill on this but just a few bumps up from stock for a more noticable power increase.
anyone know of anyone that has a P7100 pump conversion for these trucks?
Old 11-11-2010, 08:22 PM
Are these upgrades worth it??
ebay link for 3200 RPM spring and fuel pin removed
Old 11-11-2010, 09:53 PM
JBradley500's Avatar
Location: A 5th dimension, beyond that which is known to man.
id run the stock ground pin if i were you... its nearly free and should do just as good as an aftermarket pin.
id buy the 366 spring from a bosch parts dealer so you know youre getting the best one. thats my opinion of course. (probably like 20-25 dollars)
Old 11-12-2010, 08:03 AM
1st Generation Admin
BC847's Avatar
Moving to the 1st Gen forum board.
Old 11-12-2010, 10:33 AM
Were is some info on how to grind the stock fuel pin? thanks
Old 11-13-2010, 12:02 PM
Anyone?
Old 11-13-2010, 01:21 PM
https://www.dieseltruckresource.com/...s-t275712.html
Old 11-13-2010, 07:04 PM
JBradley500
wow that is some serious grinding.
Common
06-01-2008 06:15 AM
tristan21
06-19-2007 04:57 AM
75f100
11-22-2003 01:02 PM
gdh11
11-14-2003 10:37 AM
Quick Reply: stock 91 12v, cheap mods???
