PDA
View Full Version : Where To Stick It -EGT Probe Placement
Riverman777
11-23-2003, 07:04 AM
I Want to install a set of gauges (EGT, Trans Temp, Boost). I understand that its best to position the pyro probe is before the turbo. Is there a boss in the exhaust header that can be drilled and tapped or do I need to weld a plug on the exhaust or What??? Any simple solution for this?
JKE
11-23-2003, 07:13 AM
Hi Riverman,
Do a search on this. There has been much discussion and many pictures posted. You should learn exactly how and where from this....
Hope this helped.
John
