steering wheel off centre
Old 01-05-2008, 04:32 PM
dodgecbr600rr's Avatar
I dove my truck today and the steering wheel is off centre.It is a few degrees turned to the right. Yesterday the steering wheel was centred. I was wondering what happened and how to fix it. I checked all the tires for air pressure and they are all the same. Looked under the front nothing seems to be bent. Steering fluid was a bit low but that is it.
Old 01-05-2008, 04:49 PM
MMMmmmm.... Grits!!
ratlratl's Avatar
There is an adjustment sleeve just off of the pitman arm. Turn it one direction it will pull the arm one way or the other. Turn the opposite to move the other direction. I'd go and drive on more roads to make certain it is an adjusment problem before changing anything though. If you do make any adjustment make sure to tighten it back properly.
CHRIS
Old 01-05-2008, 07:46 PM
thank u i will try that tomorrow
Old 01-05-2008, 07:57 PM
rjm022's Avatar
called the drag link
rcts
11-29-2009 11:00 PM
FNJ
10-13-2005 04:42 PM
redhornet
05-26-2005 03:06 PM
FNJ
12-27-2004 07:06 AM
tool
06-09-2004 10:58 AM
Quick Reply: steering wheel off centre
