Steering very loose
Old 12-07-2006, 09:56 PM
mts-driver's Avatar
Steering very loose
I am at the point where I cant stand to drive my truck anymore because of the horrible steering on it...it wanders from side to side I have to constantly corect it I got pulled over by a cop one night coming home late he thought I was drunk I got off easy
Here is a list of what has been done;
Track bar new
checked whole front end
adjusted steering box
checked tire pressure
stock size tires
I hear you can get something that would stifen the front end and help with this problem
Old 12-08-2006, 12:06 AM
bsimmons's Avatar
might try a DSS made alot of differance on my 98 do a serch and there is alot of info on it
Old 12-08-2006, 07:39 AM
nates90's Avatar
Is it just not centering itself, or is it loose, because i know if you adjust the steering box too tight, it wont allow the alignment to center the steering all the way.....just a thought.
-Nate-
Old 12-08-2006, 08:11 AM
JVDodge's Avatar
I would take a look at a DSS as well. There is a fair amount of steering box/frame flex with the Dodge front ends. Not too expensive and easy to install yourself.
http://www.sourceautomotive.biz/steeringsuspension.htm
You might want to start with the DSS and if you still have problems, take a look at the Track Bar. <2003 Track Bars do not last very long at the ball joint. I'm installing my new track bar this weekend. I'll let you know how it works out.
Old 12-08-2006, 11:20 AM
sluggo42's Avatar
Maybe this will work for you
http://www.permashield.net/steeringfix/
Let me know, I'm looking at it too, but my steering isn't bad right now with new ball joints and an alignment.
Old 12-08-2006, 02:34 PM
alexschultz1's Avatar
did you check the pitman and idler arm bearings when you checked the front end?
eng208
27
05-20-2013 11:55 AM
Leaky Gasket
08-14-2008 07:17 AM
micstep
03-06-2005 10:08 PM
Patrick Campbell
08-20-2004 01:07 PM
Palmetto_kid
02-12-2004 10:33 AM
Quick Reply: Steering very loose
