starting/running problems
Old 09-26-2005, 07:49 PM
mainer's Avatar
Well this is not my thing, I've got myself a 1st gen. My buddy has got a newer second gen. Its a 24v 3500. It isn't starting very well.....and when it starts it wont rev up or stay running. I was thinking it is the lift pump he thinks it is a eletrical problem. Its not the fuel filter so you can rule that out. Got any Ideas for him?
Thanks Coop
Old 09-26-2005, 08:34 PM
Haulin_in_Dixie's Avatar
He needs to read his codes which will show if the VP pump is going bad. That would be his first step though, read the codes.
Old 09-27-2005, 05:18 PM
mainer's Avatar
as I said I am new to this whole computer controled engine. When you say codes do you mean hookin it up to a computer and looking at the read out? Or do you mean jumpin a fuse and counting the amount of dash lights?
Thanks Cooper
Old 09-27-2005, 06:54 PM
phox_mulder's Avatar
If it's a 2000 on up, he can turn the ignition key on/off/on/off/on (without starting, just to "on") and the codes will read out in the odometer window.
If it's a 1998.5 or 1999, he'll have to have it hooked to a scan tool to retrieve the codes.
phox
Old 09-27-2005, 07:24 PM
mainer's Avatar
Hey thanks that helps alot. will let you know when i find out wha is wong with it.
COop
fourthandgoal
88
12-27-2011 05:39 AM
DJ Turbo.
10-13-2011 09:11 PM
RED99CTD
04-20-2011 08:08 AM
abc4yew
03-15-2007 11:55 PM
simmcows
01-29-2003 09:00 PM
Quick Reply: starting/running problems
