Starting Problem
Old May 19, 2011 | 11:58 AM
joea9146's Avatar
Starting Problem
Hi
1997 147K miles has just started to have a starting problem
Problem is the same Hot or Cold no diffrence.
The motor cranks for a while before starting.
If I step on the throttle while cranking on the next revolution it will start right up. If I do not step on the throttle it cranks quite a few revolutions before it will eventually start. Anyone have any ideas of what we should look at ?
Joe
Old May 19, 2011 | 07:42 PM
sshort's Avatar
try posting in the 2nd gen forum you will get more support butfor your problem check the idle speed make sure it is idling fast enough
Old May 20, 2011 | 07:53 AM
joea9146's Avatar
Thanks I have been doing some research and I think you are correct the idle speed might be to low... I will try bumping it up only idling at about 400 rpm
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Palmetto_kid
Apr 25, 2003 05:14 PM
turbospl311
15
Jan 21, 2003 12:39 PM
