starting problem
Old 03-10-2007, 06:48 PM
GoaT94's Avatar
starting problem
well i have a 12v 94 and it take for ever to start. im new to diesels and not quite understanding everything.
so basicly call i get some pics of the relays, heater box and whatever has to do with the fuel system so i can get a better understanding of how things work.
please, and thanks for the help
Old 03-10-2007, 07:19 PM
TIMMY22's Avatar
what temps?
Here are common things to check...
1. good batteries.
2. grid heaters.
3. fuel lines for leaks.
4. overflow valve.
5. check valves in lift pump.
6. injection pump timing.
Old 03-10-2007, 08:43 PM
marv h.'s Avatar
Ya, and fuel shut off soelenoid moving all the way, clean fuel filter, and probably more coming. Good luck.
Old 03-10-2007, 08:59 PM
oldblues's Avatar
hi
do what i am doing to mine this week end !
remove all bat terminals and clean them thoughly and add a electrical connection corosion inhibitor , this will allow you to get fastest cranking from starter . mine looked good till i removed them and saw new batteries installed without being properly cleaned!
also press the acelarator slightly when crankin to give it a touch of fuel .
ease out of the throttle till it idles on its own .
Old 03-11-2007, 01:57 PM
BoostdCTD's Avatar
Does how you park affect how easily it starts? I.e. if the nose is up or down... if so then it is probably air in the lines. Even before they leak fuel they can let air into the system.
Old 03-11-2007, 02:38 PM
Box5's Avatar
Sounds like a defenite fuel delivery issue if it's just cranking over and over. Replace the fuel lines, re-prime the system and that should take that out of the equation. If not, it's good to change the lines anyway if they haven't been replaced before. If that doesn't work, come back and someone will find the problem.
Old 03-11-2007, 02:54 PM
BoostdCTD's Avatar
If you do replace the fuel lines make certain to use diesel rated hose, gas hose can't handle diesel for very long. I picked mine up at a local marine shop, pricey but I shouldn't have to ever do it again.
fourthandgoal
88
12-27-2011 05:39 AM
RED99CTD
04-20-2011 08:08 AM
abc4yew
03-15-2007 11:55 PM
Palmetto_kid
04-25-2003 05:14 PM
turbospl311
15
01-21-2003 12:39 PM
Quick Reply: starting problem
