starter
Old 11-12-2008, 06:48 PM
91.5 beater's Avatar
Help!!!!
Every once in a while i will get in my truck to start it and nothing happens and the whole truck still has power, dash warning lights, dome light, radeo, etc..., replaced the ignition feed fuse and starter relay, and nothing happened, it only does it like once every ten times i start it, it will start if i jump the terminals on the starter with a screwdriver, any comments???
Thanks, Kyle
Old 11-12-2008, 08:20 PM
dozer12216's Avatar
Need contacts insidestarter. Very common issue. Local lat/start shop will have or cna install, unless he vows must rebuild to specs. Find another or look at suppliers supporting this site. JMHO
Old 11-12-2008, 08:53 PM
I have a warranty that will cover the whole starter but wanted to make sure that that was what it was before i dropped it off at dodge, Also when it doesn't start you can hear a little tick down by the fuse box, took the cover off the fuse box and held my finger on that big blue doohicky and when you hear the click you can feel it on that blue deal, you still think it is contacts??
Old 11-13-2008, 12:40 AM
Dinner's Avatar
Yes, it's the contacts where the plunger actuates. You'll probably find one thinner, more wore out than the other. Replace both of them (and possibly plunger) and your problems should go away!
Old 11-13-2008, 09:21 AM
leeboy's Avatar
Mine did that to....I think it was a $10-$15 fix and now mines like brand new....( guy at starter store also said very common)
Old 11-13-2008, 10:45 AM
PRG
PRG's Avatar
I installed the heavy duty contacts and plunger from Larry B's and have had 0 problems. A very inexpensive and easy fix for this common problem.
Old 11-13-2008, 12:04 PM
nitrousn's Avatar
Looksee here.
http://cgi.ebay.com/ebaymotors/New-g...QQcmdZViewItem
Old 11-13-2008, 07:42 PM
alright then ill drop her off at dodge next week and get her fixed, thanks for all your alls input
Old 11-14-2008, 09:02 AM
Junk Man's Avatar
Don't spend any $$ at the ***********. It's a simple fix.
Old 11-15-2008, 03:29 PM
It is free and i dont have to touch it i had them order the parts, they are puttin a whole new starter in and it will only be at dodge for 2 hours they said so it aint a big deal
FMB
11-14-2010 09:09 PM
12valvesmoke
06-12-2009 09:46 AM
buckman361
11-13-2008 09:54 AM
Paradise Racing
01-18-2005 09:08 AM
MJR
03-16-2003 08:26 PM
Quick Reply: starter
