Starter Problem Help
Old 11-06-2006, 03:23 PM
dpeder's Avatar
Something strange happening to my 97 starter just clicks when truck is first started in the cool weather I have to keep switching the ignition switch on and off and finally it engages the starter and fires right up batterys seem to be OK and after truck is once started it won't do it again until the next morning??? Maybe the soloniod?? or starter motor?? Ignition switch??
Don
Old 11-06-2006, 05:06 PM
Racer9's Avatar
This is probably what you need http://www.fostertruck.com/dodge/default.htm
Common problem.
Old 11-06-2006, 05:09 PM
BBWD's Avatar
Don:
How many miles on the truck? The starter contacts usually go out at about 100K - 125K miles and the starter acts the way you describe it. If you don't get it fixed pronto, you run the risk of the starter staying engaged when the contacts lock up and won't release and that is a good way to ruin the starter and possibly burning up the relay. If you are over 100K and have not replaced them, this is the first thing I would do to trouble shoot. You can get them from Fosters on the west coast cheap and they are easy to install. Their phone number is (253) 272-1444 or (800) 414-0769. The other option which costs a little more is to buy a rebuilt starter.
Also, you should probably check all your connections and grounds to make sure they are clean.
John (DH)
Old 11-06-2006, 07:03 PM
TIMMY22's Avatar
lemme guess,
you want to smack that gorilla that was working at cummins who tightened those 12 point starter bolts
Old 11-07-2006, 08:21 AM
T-Bone's Avatar
I second the contacts. Mine looked just like the bad ones here. I got very lucky on the bolts. I had an oil leak that soaked the starter for a few months before I got the leak stopped. Made for real easy removal! One hour start to finish.
T-Bone
Old 11-07-2006, 08:25 AM
Geico266's Avatar
Take a look at my old ones.
Old 11-07-2006, 09:44 AM
dpeder's Avatar
Thanks alot for the replys the truck has 78000 miles on it but will replace the contacts sounds easy and cheap Thanks again you guys are great
Don
Red3quarter
09-09-2012 05:25 PM
FMB
11-14-2010 09:09 PM
12valvesmoke
06-12-2009 09:46 AM
buckman361
11-13-2008 09:54 AM
Paradise Racing
01-18-2005 09:08 AM
Quick Reply: Starter Problem Help
