stalling in reverse
Old Jun 24, 2006 | 01:02 PM
beaner's Avatar
Question stalling in reverse
Hi! I have a 95 with a bd torque converter fuel plate ,Automatic it has started stalling when I put it into reverse either hot or cold moreso hot though. The odd time will also stall with Air conditioning on and a hard slow turn. Could this be an idle issue it seems to be idling lower then normal when I put into gear. Also is ther and idle compensater for when the air conditioning is on.Any words of Wisdom would be appreciated.
Old Jun 24, 2006 | 01:24 PM
GearHd6's Avatar
Its supposed to idle at 750-800 in drive with the AC on. There is no idle compensator. Whats yours idling at in drive with AC on?
Old Jun 24, 2006 | 11:23 PM
cody@nl'sCTD's Avatar
ac
start from there, where is ur idle at when ac is on in drive?
Old Jun 25, 2006 | 09:06 AM
12vchevydually's Avatar
Sounds Like you may have a issue in the Pump.?
Old Jun 25, 2006 | 01:38 PM
beaner's Avatar
going by the stock Tach you have 0 one line then a second line then 1000 RPM it is idling below the second line in drive with air on it dips lower when compressor kicks in and a little lower when I put it in reverse.Sorry I do not know what Revs are on the unmarked lines
Old Jun 25, 2006 | 01:39 PM
beaner's Avatar
The truck has 137,000 Kms on it
Old Jun 25, 2006 | 04:18 PM
GearHd6's Avatar
Sounds like your idling under 500 rpms to me. It should be between the 2nd line and the 1000 mark. Thats why its stalling. Heres the link to help you turn it up. http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Old Jun 25, 2006 | 06:10 PM
beaner's Avatar
Smile
Thanks I have been wondering this for awhile as the other CTD seem to be idling faster then mine I will try this and let you know Love the Truck
Old Jul 4, 2006 | 10:35 PM
beaner's Avatar
Okay I have adjusted the idle it is idling at just a little bit above the second line with the air on and in drive with the brake on. in neutral it is idling at about 3/4 of the way to the 1000 is this better it or is it idling to high in neutral
Old Jul 5, 2006 | 01:12 AM
solid_st8's Avatar
sounds like you could bump it up a little more, it should be right below the 1 mark in neutral, and about halfway between the half mark and 1, which is 750, in drive. hope that makes since.
Old Jul 5, 2006 | 07:52 AM
Rrloren's Avatar
Each line represents 125 RPM. Get it to at least 750 in Drive with a/c on.
Old Jul 5, 2006 | 07:02 PM
beaner's Avatar
Okay thanks that gives me a better idea guys
Old Jul 5, 2006 | 07:59 PM
Dr. Evil's Avatar
yup, its still too low, IMO.
dodge88
Feb 23, 2015 12:53 PM
MAC702
Jun 28, 2011 05:18 PM
nick2001
Nov 13, 2008 03:49 PM
steelblitzkrieg
Jul 2, 2008 12:47 PM
richard
Nov 23, 2002 03:03 AM
