stage 2 cp3 problem??
I got my flux 3.5 installed and a stage 2 cp3 from floor it. The problem I am having is when the truck is in gear with the brake applied at a stop light the truck seems to have a slight lope in the idle. You can hear it in the stacks and if I watch the tach it is moving up and down about 50 rpms. Put the truck in park and it idles fine no lope. Is this normal with a stage 2 pump? Any ideas guys??
You may have a piece of debree on the fca. The FCA is very sensitive on these pumps. Take the 3 bolts out of the back and clean it off with filmless brake cleaner or something and see if that takes care of it. I am running the same inj and pump as you and mine doesn't lobe.
That's what I was thinking!
Can't seem to get rid of the ol' hi-po gasser inside me...
gotta love a big lope and surge through the converter every couple of seconds!
For 50RPM, I'd just tell everyone it's your Helix 5 cam
Jethro6213
19
07-11-2008 11:59 AM
Doubleover
04-21-2006 02:38 AM
052500#1
13
01-06-2006 03:27 PM
