Stage 2 cp3, how much HP
Old 08-27-2007, 08:42 PM
cvcook's Avatar
How much HP can be had on a stage 2 cp3, I know duals is the ultimate, but I might not be able to wait to save up. Also, whose pump would you recommend, down time is not a problem since I have a second truck
thanks, Charlie
Old 08-27-2007, 08:56 PM
CReed's Avatar
Heard good things from floor it and II . Its all in prefrence i guess I think im just gna do without until I get $ for relentless duals.
Old 08-27-2007, 09:45 PM
PourinDiesel's Avatar
Save the money for duals if you are shooting for max power.
Old 08-28-2007, 02:30 AM
Megacab07's Avatar
can you put twins on and run fine without dual cp3. Or how can you get enough fuel to hit about 500-600 hp range. I am work on upgrading my lift put and I am also installing the GPD big line kit in with the 2 micron filter.
Old 08-28-2007, 02:41 AM
With a modded single cp3 you should be able to hit 600hp with the right mods.
Old 08-28-2007, 07:48 AM
cvcook's Avatar
No drugs right?
Old 08-28-2007, 08:56 AM
chrleb1's Avatar
I did 765 with a stage 2. But I did have some spray going to the motor. I didn't get to dyno without it, but I'm sure it's only about a 100 shot. Last year, Reb did a little over 700 with a stage 2 (on the motor) and 893 on the spray.
Jethro6213
19
07-11-2008 11:59 AM
PourinDiesel
15
06-16-2008 09:51 AM
CTDinMT
09-02-2007 04:05 PM
052500#1
13
01-06-2006 03:27 PM
timb
08-19-2005 10:16 PM
Quick Reply: Stage 2 cp3, how much HP
