Stage 2 cp3 or dual cp3's on a daily driver
Old 10-16-2007, 09:07 AM
Jethro6213's Avatar
What would be better for a daily driver? I am going to do injectors, turbo, FASS, Smarty etc. Just wanting to know if dual cp3's would be worth the extra money or not. I would really like to be in the high 500 to low 600hp range. Thanks
Old 10-16-2007, 09:20 AM
Winner winner chicken dinner!
RyeThomas's Avatar
Stage 2 or 3 is more than enough for 600hp. I went from a stage 2 to duals, and with added pressure my truck is more responsive with duals. With the single pump I would get an initial drop then a quick recover, with duals my pressure goes 1 way and thats up. As far as the seat of the pants, when Im not running pressure I really cant tell a difference.
Old 10-16-2007, 09:22 AM
Boz007's Avatar
I like the idea of the dual pumps. I would rather have two pumps doing the same amount of work as one hopped up pump.
Old 10-16-2007, 09:27 AM
PourinDiesel's Avatar
If you just want to spin a dyno then a stage 2 is just fine. If you want to go nuts with power then the duals are the way.
Old 10-16-2007, 09:32 AM
Jethro6213's Avatar
I am planning on running just the Smarty and no pressure box. Do ya'll feel the duals are more reliable and dependable than a stage 2 pump?
Old 10-16-2007, 12:07 PM
rustyshakelford's Avatar
i think you would be fine with a single pump is thats all your planning on running! if you have the extra cabbage or might want to get a little more extreme go w/ the dual pumps
brett
Old 10-16-2007, 12:18 PM
O.T
O.T's Avatar
Jethro you can always go with twin pumps down the road, I have a floor it stg 2 on the bottom and a ppe stock on the top.
As Rye said with out pressure things are pretty comparible to one modded single pump. With pressure things are much different. I ended up having to add a second 392 walbro to maintain feed pressure.
onetun
Old 10-16-2007, 01:00 PM
Jethro6213's Avatar
If I run one of the newer versions of the Smarty do they have pressure built in to there programs? If so will I still be ok to run a newer Smarty with a stage 2 pump.
Old 10-16-2007, 02:02 PM
AnythingDiesel's Avatar
If your shooting for 600hp then duals are a must especially on a 03. Not to mention a dual setup is a lot more reliable then a hot rod single.
Old 10-16-2007, 02:08 PM
essgeetee's Avatar
Smarty 4.4 Beta does add pressure.
Old 10-16-2007, 10:34 PM
kevins600's Avatar
Tomeygun dynoed 604 with an early stage 1 floor it pump. He's got a Cali edition 250 hp 03.
Old 10-17-2007, 12:29 AM
Jethro6213's Avatar
Thanks guys. After talking to Tim yesterday I think I am going to go with the PPE dual fuelers. Thanks again for the help.
Old 10-17-2007, 12:34 AM
morkable's Avatar
I ran 632 with a stage 2 from IIS. 50 hp DDP injectors and a Silverbullet.. Hot edge diablosport stack.... But I have to say I think that I really like the duals now,, but they are a few extra bucks that is for sure
Kevin
Old 10-17-2007, 07:57 AM
OT-OF-Here's Avatar
Dual cp3s
I've gone with a lvl 2 cp3 and now with dual cp3s. The duals are the way to go. From what I've seen you'll find the best pricing with these two sources:
1) Relentless (if you have your own two Dodge pumps)
2) Sootman (you'll find him on the Comp Diesel Forum and he's a distributor for PPE and will give you the very best price on their setup. He can also sell you their setup less the pumps, if you have your own).
As others have stated, VOLUME is the word, especially with dual cp3s so eith dual lift pumps or the Mitusa can take care of the job. Opie has two versions of the Mitusa and one will take care of your needs to low 700hp and then he has a Mac Daddy pump for over that, fyi. His pumps are very reasonable compared to anyone's and his big pump will do 275gph on a continuous basis and is supporting R. C. ***'s truck at 1200hp with no problem. It's a great value and keeps you at one lift pump. I have my GDP Walbro electrically looped in just in case and can turn it on in an as needed basis for security. By the way, Timinva runs a Mitusa to support his dual cp3s,.... does it tell ya something?
Old 10-17-2007, 08:45 AM
Jethro6213's Avatar
Thanks for the info. I have to call Tim, I will ask him about the Mitusa.
Quick Reply: Stage 2 cp3 or dual cp3's on a daily driver
