Stacking Superchips and Edge Juice / Defueling
Old 02-17-2010, 04:02 PM
sheriffav8r's Avatar
Does anyone have the Superchips MT3705 and the Edge Juice with Attitude stacked? It seems that if I just have my truck stock (no programmer or chip) I can get 30psi from my little turbo. When I put on the programmer on HI-PERF I only get about 25psi. It also feels like it's defueling when I have the programmer on with the Edge.... Anyone?
Old 02-17-2010, 08:27 PM
illEatUrDuramax's Avatar
what boost are you making when you're only running one of them? try that. perhaps they could be interfering with each other running at the same time? i dont know for sure though. someone who knows more about this should chime in
Old 02-18-2010, 07:52 AM
OldDodgeOwner's Avatar
Probably not a real good idea to run both. Both of those add timing I believe.
Old 02-18-2010, 08:21 AM
high bid's Avatar
Yep. Schip and Edge will both add timing. The two chips are probably fighting it out.... "NO I get to add the timing you add the fuel this time."
I'd ditch the schip (see my sig).
Old 02-18-2010, 01:21 PM
With just the Schip I max out at 26+/- psi. With the Edge it depends on what level I run at (Level 1=20, 2=25, 3=30, 4,5=A Lot). I thought the Superchips used the VP to draw out injector timing and the Edge used its own electronics to do it. I would run just the Edge but I like the tire size fixer on the Superchips and I can't use that without using the performance program.
Old 02-18-2010, 03:17 PM
high bid's Avatar
I'm not 100% sure the Schip does boost fooling either...mine didn't. With that said you're lucky to get 26psi out of it. I just had the program loaded on my truck when purchased, not the programmer itself.
Old 02-18-2010, 04:29 PM
ya i was gonna add in about both adding timing. I would run only one of them
Havic801
11-16-2011 02:34 PM
rogerr03
06-05-2010 02:12 PM
hotrod929
12-27-2006 11:10 PM
razor6
22
01-20-2006 03:43 PM
Quick Reply: Stacking Superchips and Edge Juice / Defueling
